[Qgis-user] TauDEM
Werner Macho
werner.macho at gmail.com
Tue Apr 4 10:41:29 PDT 2017
Hi!
I'm using TauDEM here on an OSGEO4W installation without problems.
But I have to say I always use the standard installation paths.
Recently there were some problems but that is already corrected and
should not affect you in any way.
Probably you should just try the standard paths?
regards
Werner
On 04/04/17 17:13, ALT SHN wrote:
> Dear All,
> I am trying to enable TauDEM provider, but so far no success. This is
> what I have tried:
> 1- I used the complete Full Windows Installer from
> here http://hydrology.usu.edu/taudem/taudem5/downloads2.html
> 2 - MPICH2/OpenMPI bin directory: D:\Microsoft_MPI\Bin
> 3 - TauDEM command line tools folder: ~\tauDEM_64
> Whenever I try to run a tool, the processing dialog returns:
> '"D"' is not recognized as an internal or external command,
> operable program or batch file.
> Converting outputs
> Loading resulting layers
> The following layers were not correctly generated.
> * Longest Upslope Length Grid
> * Total Upslope Length Grid
> * Strahler Network Order Grid
> You can check the log messages to find more information about the
> execution of the algorithm
> It looks like the Path is being taken as part of the command that is
> launched.
> Has anyone manage to use this provider? Any suggestions?
> Thanks
> *Sociedade de História Natural*
> Departamento de Informação Geográfica
> Polígono Industrial do Alto do Amial
> Pav.H02 e H06
> i.geografica at alt-shn.org <mailto:laboratorio at alt-shn.org>
> www.shn.pt <http://www.shn.pt>
> www.alt-shn.blogspot.com <http://www.alt-shn.blogspot.com>
> Facebook <https://www.facebook.com/SociedadeDeHistoriaNatural?ref=hl>
> TLM: 964138188
> Qgis-user mailing list
