[Qgis-user] Can not install qgis-mapserver on CentOS 7
Nicolas Boisteault
boisteault at observatoire-environnement.org
Thu Apr 13 00:08:18 PDT 2017
Hi Julian,
This guide is old and I think not updated. The version 1.8 of QGIS is
too old. You should use
http://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/ogc_server_support.html
[5]. Unfortunately the installation is explained for Ubuntu.
You can try this too
https://www.qgis.org/fr/site/forusers/alldownloads.html#id17
Le 2017-04-12 19:53, Julian Bogdani a écrit :
> Hello everybody,
> I'm trying to setup a QGis server on a CentOS (7.3.1611) server, following the official guide: http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial [2]
> I followed the instructions and added EPEL:
>> yum install epel-release
> Then I added ELGIS:
>> rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm [1]
> And finally tried to install qgis-mapserver:
>> yum install qgis-mapserver
> But this last command did not work, because some dependencies were not met:
>> Error: Package: qgis-1.8.0-9_0.el6.x86_64 (elgis)
>> Requires: libqwt.so.5()(64bit)
>> Requires: libqwtpolar.so.0()(64bit)
>> Error: Package: mod_fcgid-2.3.9-4.el7.x86_64 (base)
>> Requires: httpd-mmn = 20120211x8664
>> Requires: libspatialindex.so.1()(64bit)
>> Error: Package: qgis-mapserver-1.8.0-9_0.el6.x86_64 (elgis)
> Am I missing anything? Should I install these dependencies manually? Or should I install some other package before?
> Any help would be much appreciated,
> Thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net [3]
> Qgis-user mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user [4]
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user [4]
Links:
[1] http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
[2] http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial
[3] http://bradypus.net
[4] https://lists.osgeo.org/mailman/listinfo/qgis-user
[5]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170413/cef7669d/attachment.html>
