[Qgis-user] Bug copying features
Richard Duivenvoorde
rdmailings at duif.net
Thu Apr 20 05:42:21 PDT 2017
On 20-04-17 09:26, Reginald Carlier wrote:
> Hello,
> I am using QGIS 2.18.6 on Windows 7 (OSGEO).
> I am encountering a bug everytime I want to copy features from one layer
> to another. Some fields of layer 1 are the same in layer 2.
> As I add the layers to the project, I then set the two layers editable.
> Then I open the attribute table of layer 1 and select all the features.
> Then I copy all the features. Then I select layer2 and I paste all the
> features. As a result the features are copied to layer 2 but in the
> attribute table I can only see null values.
> The solution for this problem is to save the project and reopen the
> project and then do the steps mentioned here above again. Then the
> features are copied in a correct way.
Hi Reginald,
I tried to reproduce your problem here with 2.18.6 (on Debian though).
And I cannot reproduce it. I:
- opened a dataset and saved it as a 2nd shape
- removed all features from the 2nd shape (to have a shape with exact
the same attributes)
- openend both shapes in QGIS
- copied one feature from 1 to 2
- stopped editing of both layers
- note: still not a saved project
- and see the right features in 2...
So question: is your second dataset maybe ANOTHER shape with a subset of
the attributes of the first one?
Anyway, this looks like an issue, feel free to create an issue for it,
BUT make it as reproducable as possible: add small datasets to it.
Because as you can see it's not easy to reproduce apparently :-(
Regards,
