[Qgis-user] GDAL 2.2.0 install and QGIS removed
Jürgen E. Fischer jef at norbit.de
Tue Aug 8 01:28:34 PDT 2017
Hi Micha,
On Tue, 08. Aug 2017 at 11:08:20 +0300, Micha Silver wrote:
> I see the warning about testing builds. But since 2.18.11 is called "LTR
> candidate" it's not clear that this version is in fact still under
> testing.
But it should as the state of QGIS doesn't really apply here.  What's causing
issues is not QGIS itself, but the dependencies underneath.  If you choose a
unstable base, you implicitly risk that QGIS might break - while the very same
QGIS on a stable base stays unaffected.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170808/4eb19ec7/attachment.sig>
