[Qgis-user] Georeferenced work won't write to file
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Aug 12 09:59:17 PDT 2017
Did you specify the file name in a existing directory?
Nicolas
> Le 12 août 2017 à 10:00, Charles Barrows [via OSGeo.org] <ml+s1560n5331337h8 at n6.nabble.com> a écrit :
> Georeferenced work won’t write to file
> Cannot figure out what I’m doing wrong.  My georeferenced work on a raster file contains 7 points in the GCP table.  The pixel/Easting/Northings  calculated with no trouble and filled the table.  The data points with labels show up on the raster display.  Using Thin Plate Spline, which was the only transform type that has worked for me before.  Resampling method Nearest Neighbor.  Target SRS: (Kansas South)  Everything sets up, but after clicking OK the modified.TIF file doesn’t show up anywhere on the disk drive.
> Frustrated in Denver
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Georeferenced-work-won-t-write-to-file-tp5331337.html
> To start a new topic under QGIS - User, email ml+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Georeferenced-work-won-t-write-to-file-tp5331337p5331350.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170812/4ae21a05/attachment.html>
