[Qgis-user] Georeferenced work won't write to file
    Karl Magnus Jönsson
    Karl-Magnus.Jonsson at kristianstad.se
    Sun Aug 13 23:28:17 PDT 2017
Hi!
Did you hit the ”play”-button (green triangle)? Otherwise nothing happens. It’s just the settings. Could be a litte unclear.
Karl-Magnus Jönsson | Gis-Utvecklare
Geografisk information
Miljö- och samhällsbyggnadsförvaltningen
Kristianstads kommun
Besöksadress: Västra Storgatan 12
Postadress: 291 80 Kristianstad
www.kristianstad.se
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Nicolas Cadieux
Skickat: den 12 augusti 2017 18:59
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Georeferenced work won't write to file
Did you specify the file name in a existing directory?
Nicolas
Le 12 août 2017 à 10:00, Charles Barrows [via OSGeo.org<http://OSGeo.org>] <[hidden email]</user/SendEmail.jtp?type=node&node=5331350&i=0>> a écrit :
Georeferenced work won’t write to file
Cannot figure out what I’m doing wrong.  My georeferenced work on a raster file contains 7 points in the GCP table.  The pixel/Easting/Northings  calculated with no trouble and filled the table.  The data points with labels show up on the raster display.  Using Thin Plate Spline, which was the only transform type that has worked for me before.  Resampling method Nearest Neighbor.  Target SRS: (Kansas South)  Everything sets up, but after clicking OK the modified.TIF file doesn’t show up anywhere on the disk drive.
Frustrated in Denver
Qgis-user mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5331337&i=0>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Georeferenced-work-won-t-write-to-file-tp5331337.html
To start a new topic under QGIS - User, email [hidden email]</user/SendEmail.jtp?type=node&node=5331350&i=1>
To unsubscribe from QGIS - User, click here.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Georeferenced work won't write to file<http://osgeo-org.1560.x6.nabble.com/Georeferenced-work-won-t-write-to-file-tp5331337p5331350.html>
Sent from the QGIS - User mailing list archive<http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170814/80a0f415/attachment.html>
