[Qgis-user] Updating a field set with default global variable on edit
Fernando M. Roxo da Motta petro at roxo.org
Tue Aug 22 17:28:12 PDT 2017
On Tue, 22 Aug 2017 15:45:17 +0200, Casper Bertelsen
<casperbj94 at gmail.com> wrote:
> Hi Ross,
> If you make your project without saving username and password, the
> project will prompt for a user and password when opened. Then each
> member can login using their assigned login and thus making it
> possible to use current_user in postgres.
> To remove saved username and password from your current project file
> (make a copy, beforehand), you can open it in a text editor and seach
> for <layername> untill you find
  It seems to me that this can be useful for a lot of groups.   Could
this kind of save option be an interesting request for improvement?
  Slds.
> <datasource>dbname='xx' host=yy port=5432 four lines above
> <layername>and remove the username and password-part only .
> Mvh. / Best regards
> Casper Bertelsen
> On 22/08/2017 15:36, McDonaldR wrote:
> > Thanks Karl-Magnus
> > We use triggers in the database already and they work perfectly but
> > if we want to record the specific user creating and editing
> > features then we’d have to create separate projects for each user.
> > At the moment the team of about 10 users all use a set of centrally
> > stored project files – one for each different task.
> > I found this post on Stackexchange
> > (https://gis.stackexchange.com/questions/217011/how-to-automatically-update-wfs-edits-with-a-user-id)
> > where global variables are used to populate fields when features
> > are added.  However, as Matthias notes in the comments this doesn’t
> > work on feature  “update”.  If this were possible then it would
> > meet all our needs.  Maybe something that could be funded?
> > Ross
> > *From:*Karl Magnus Jönsson
> > [mailto:Karl-Magnus.Jonsson at kristianstad.se] *Sent:* 22 August 2017
> > 12:34 *To:* McDonaldR; qgis-user at lists.osgeo.org
> > *Subject:* SV: [Qgis-user] Updating a field set with default global
> > variable on edit
> > Hi!
> > I’ve made the same things with triggers in the database. To avoid
> > getting same username I’ve chosen not to save the username and
> > password in the project. But then the user have to enter it every
> > time the projects opens. If you can find a solution to your
> > suggested approach it would be nice.
> > *Karl-Magnus *
> > *Från:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För
> > *McDonaldR
> > *Skickat:* den 22 augusti 2017 13:12
> > *Till:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> > *Ämne:* [Qgis-user] Updating a field set with default global
> > variable on edit
> > Hi List,
> > Anyone know how to update a field that has a global variable set as
> > the default value when records are edited (geometry and/or
> > attributes)?
> > We have a QGIS project with a PostGIS layer loaded and configured
> > with look-ups and relations so the users can update all the
> > relevant fields. There are also "*created_by*" and "*updated_by*"
> > fields. These are updated by a trigger in the database with the
> > "*current_user*" database variable. This works fine if you are the
> > current user that added the layer to the project - the trigger
> > works perfectly.
> > If you give the project to someone else and they create and edit
> > features in the layer the fields are still updated with your name
> > as you are the person who added the layer to the project. Not what
> > we want.
> > QGIS has global variables and there are some new ones -
> > *user_account_name* and *user_full_name* that can be set as default
> > values for the fields. When a new feature is created the field is
> > populated with the correct name. Which is what we want.
> > However, when we update an existing record we'd like the
> > "*updated_by*" field to be updated with the current
> > "*user_account_name*". Like a trigger in the database would do on
> > update. Then we would have a better idea of the history of the
> > feature.
> > Ross
> > *Ross McDonald | *GIS Data Coordinator | Angus Council, People, IT
> > | Angus House, Orchardbank Business Park, Sylvie Way, Forfar DD8
> > | 1AT*|
> > t: 01307 476419*
> > This message is strictly confidential. If you have received this in
> > error, please inform the sender and remove it from your system. If
> > received in error you may not copy, print, forward or use it or any
> > attachment in any way. This message is not capable of creating a
> > legal contract or a binding representation and does not represent
> > the views of Angus Council. Emails may be monitored for security
> > and network management reasons. Messages containing inappropriate
> > content may be intercepted. Angus Council does not accept any
> > liability for any harm that may be caused to the recipient system
> > or data on it by this message or any attachment.
> > and network management reasons.Messages containing inappropriate
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
