[Qgis-user] Updating a field set with default global variable on edit
Germán Carrillo carrillo.german at gmail.com
Tue Aug 22 07:37:26 PDT 2017
Hi All,
to get field updates on vector layer edits (be they geometry or attribute
edits) you can use the AutoFields plugin [1]. You can use expressions just
like you do when setting default values in QGIS.
Regards,
Germán
[1]
http://geotux.tuxfamily.org/index.php/en/geo-blogs/item/333-autofields-plugin-for-qgis
2017-08-22 8:45 GMT-05:00 Casper Bertelsen <casperbj94 at gmail.com>:
> Hi Ross,
> If you make your project without saving username and password, the project
> will prompt for a user and password when opened. Then each member can login
> using their assigned login and thus making it possible to use current_user
> in postgres.
> To remove saved username and password from your current project file (make
> a copy, beforehand), you can open it in a text editor and seach for
> <layername> untill you find
> <datasource>dbname='xx' host=yy port=5432 four lines above <layername>
> and remove the username and password-part only .
> Mvh. / Best regards
> Casper Bertelsen
> On 22/08/2017 15:36, McDonaldR wrote:
> Thanks Karl-Magnus
> We use triggers in the database already and they work perfectly but if we
> want to record the specific user creating and editing features then we’d
> have to create separate projects for each user.  At the moment the team of
> about 10 users all use a set of centrally stored project files – one for
> each different task.
> I found this post on Stackexchange (https://gis.stackexchange.
> com/questions/217011/how-to-automatically-update-wfs-edits-with-a-user-id)
> where global variables are used to populate fields when features are
> added.  However, as Matthias notes in the comments this doesn’t work on
> feature  “update”.  If this were possible then it would meet all our
> needs.  Maybe something that could be funded?
> Ross
> *From:* Karl Magnus Jönsson [mailto:Karl-Magnus.Jonsson at kristianstad.se
> <Karl-Magnus.Jonsson at kristianstad.se>]
> *Sent:* 22 August 2017 12:34
> *To:* McDonaldR; qgis-user at lists.osgeo.org
> *Subject:* SV: [Qgis-user] Updating a field set with default global
> variable on edit
> Hi!
> I’ve made the same things with triggers in the database. To avoid getting
> same username I’ve chosen not to save the username and password in the
> project. But then the user have to enter it every time the projects opens.
> If you can find a solution to your suggested approach it would be nice.
> *Karl-Magnus *
> *Från:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <qgis-user-bounces at lists.osgeo.org>] *För *McDonaldR
> *Skickat:* den 22 augusti 2017 13:12
> *Till:* qgis-user at lists.osgeo.org
> *Ämne:* [Qgis-user] Updating a field set with default global variable on
> edit
> Hi List,
> Anyone know how to update a field that has a global variable set as the
> default value when records are edited (geometry and/or attributes)?
> We have a QGIS project with a PostGIS layer loaded and configured with
> look-ups and relations so the users can update all the relevant fields.
> There are also "*created_by*" and "*updated_by*" fields. These are
> updated by a trigger in the database with the "*current_user*" database
> variable. This works fine if you are the current user that added the layer
> to the project - the trigger works perfectly.
> If you give the project to someone else and they create and edit features
> in the layer the fields are still updated with your name as you are the
> person who added the layer to the project. Not what we want.
> QGIS has global variables and there are some new ones -
> *user_account_name* and *user_full_name* that can be set as default
> values for the fields. When a new feature is created the field is populated
> with the correct name. Which is what we want.
> However, when we update an existing record we'd like the "*updated_by*"
> field to be updated with the current "*user_account_name*". Like a
> trigger in the database would do on update. Then we would have a better
> idea of the history of the feature.
> Ross
> *Ross McDonald | *GIS Data Coordinator | Angus Council, People, IT |
> Angus House, Orchardbank Business Park, Sylvie Way, Forfar DD8 1AT* | t:
> 01307 476419*
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Qgis-user mailing listQgis-user at lists.osgeo.org
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://twitter.com/GeoTux2
http://about.me/germancarrillo
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170822/f53149ec/attachment.html>
