[Qgis-user] Problem on saving result in a Data Base
DelazJ delazj at gmail.com
Fri Feb 3 05:33:36 PST 2017
The '...' button near the Dissolved output textbox provides you with
different means of storage of the output, namely, "temporary file", "file",
"SpatiaLite", "PostGIS" and a "Use expression..." option I do not see what
it could be about, yet.
So, yes, it should be possible to set your output format.
Regards,
Harrissou
2017-02-03 14:14 GMT+01:00 Stefano Niccolai <niccolai at ldpgis.it>:
> Hi,
> I'm using QGIS 2.18.3 on Windows 10 and I would like to make a question to
> you.
> Is it possible to save the geoprocessing results into an existing Database
> (Postgres with Postgis extention, SQLite and others)?
> For example:
> Given an existing Database( *MyDB.sqlite* ) and an existing Table(
> *MyDB.table_1*) , I would like to save the result coming from the
> geoprocessing function *Dissolve* (ran on  table_1) in the db table
> *MyDB.table_result. *Thank you for your time and have a nice day,
> Stefano.
> Pianif. Stefano Niccolai
> LdP Progetti GIS
> email: niccolai at ldpgis.it
> Tel: 0577-531049
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170203/2e7d94ec/attachment.html>
