[Qgis-user] Join hangs in Las Palmas
Andreas Wicht
a.wicht at gmail.com
Wed Feb 8 01:42:25 PST 2017
I recently encountered that issue as well and I observed the behavior
only when the attribute table was opened.
For me it works just fine when I close the attribute table (no matter
if docked or undocked) before I do the join.
Maybe try that for a start.
Still, I think that problem should be investigated in more detail.
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
> Bernd Vogelgesang
> Sent: Dienstag, 7. Februar 2017 13:52
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Join hangs in Las Palmas
> Hi,
> did you already try to create a new joined layer with the processing toolbox
> instead of creating a "loose" join with Properties/Joins?
> I almost never do joins through the properties but instead create permanent
> joins with "Join attributes table" from the toolbox.
> It could be possible that your machine has not enough power/memory when
> non-permanently joining huge data sets.
> Good luck
> Bernd
>> Am 06.02.2017, 21:16 Uhr, schrieb Holly Wilkie <bells.holly at gmail.com>:
>> Hi, I've noticed that when I try to do a Join, the software hangs and I have
>> to close the App. Usually, the join works after I restart. However, I am
>> currently trying to join a table of parcel ownership data provided by a
>> Texas county with a shapefile provided by the same county. The data type for
>> the columns is the same. They are both rather large files. When I set up the
>> join, QGIS hangs and I am unable to get the join to work upon restarting.
>> Has anyone else noticed this issue?
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
