[Qgis-user] Join hangs in Las Palmas
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Feb 7 04:51:51 PST 2017
did you already try to create a new joined layer with the processing
toolbox instead of creating a "loose" join with Properties/Joins?
I almost never do joins through the properties but instead create
permanent joins with "Join attributes table" from the toolbox.
It could be possible that your machine has not enough power/memory when
non-permanently joining huge data sets.
Good luck
Bernd
Am 06.02.2017, 21:16 Uhr, schrieb Holly Wilkie <bells.holly at gmail.com>:
> Hi, I've noticed that when I try to do a Join, the software hangs and I
> have to close the App. Usually, the join works after I restart. However,
> I am >currently trying to join a table of parcel ownership data provided
> by a Texas county with a shapefile provided by the same county. The data
> type for the >columns is the same. They are both rather large files.
> When I set up the join, QGIS hangs and I am unable to get the join to
> work upon restarting. Has >anyone else noticed this issue?
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170207/7ca29794/attachment.html>
