[Qgis-user] Is there any way to constrain the resources QGis uses?
Neumann, Andreas
a.neumann at carto.net
Thu Feb 9 06:26:00 PST 2017
Hi Ian,
You can limit the nr of CPU cores it uses for rendering:
Settings --> Options --> Rendering --> Render layers in parallel / Max
cores
I don't think you can limit memory consumption with QGIS settings.
Andreas
On 2017-02-09 14:31, Ian Turton wrote:
> I know that sounds like something you wouldn't want to do but we have a number of users sharing a VM and if the first QGis started manages to grab all (or even most) of the available memory it prevents the other users from being able to start QGis let alone use it.
> Cheers
> Ian
> Ian Turton
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170209/1254ccbc/attachment.html>
