[Qgis-user] Is there any way to constrain the resources QGis uses?
Ian Turton
ijturton at gmail.com
Fri Feb 10 06:04:12 PST 2017
We have several users on the same VM which is what causes the contention
for memory
Ian
On 10 February 2017 at 13:44, Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Ian,
> You could try to limit the max amount of ram available for each VM, this
> would have been done when each, was created, you should probably start
> there!
> Its under Settings, System, Motherboard and Base Memory, I would say
> reduce it so as each VM has equal Memory and you leave a bit for the host.
> Regards,
> Richard.
> On 09/02/2017 14:26, Neumann, Andreas wrote:
> Hi Ian,
> You can limit the nr of CPU cores it uses for rendering:
> Settings --> Options --> Rendering --> Render layers in parallel / Max
> cores
> I don't think you can limit memory consumption with QGIS settings.
> Andreas
> On 2017-02-09 14:31, Ian Turton wrote:
> I know that sounds like something you wouldn't want to do but we have a
> number of users sharing a VM and if the first QGis started manages to grab
> all (or even most) of the available memory it prevents the other users from
> being able to start QGis let alone use it.
> Cheers
> Ian
> Ian Turton
> Qgis-user mailing list
> Qgis-user mailing listQgis-user at lists.osgeo.org
> *Richard McDonnell*
> *GIS Specialist PgD GIS AssocSCSI*
> *OPW FRM Data Management*
> *52 Stephens Green, Dublin 2.*
> TEL: 01 6476543
> <http://www.opw.ie/>
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170210/17257ef3/attachment.html>
