[Qgis-user] Is there any way to constrain the resources QGis uses?
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Feb 10 06:16:28 PST 2017
Qgis works well with 4GB of memory on windows 7-64 for simple projects. If possible, I would have more that one VM that would be configured with each 4GB of ram and limit 1 user at a time per VM. If your server can handle the load, that would be the best way to go it think.
Nicolas
> Le 10 févr. 2017 à 09:04, Ian Turton [via OSGeo.org] <ml-node+s1560n5307432h53 at n6.nabble.com> a écrit :
> We have several users on the same VM which is what causes the contention for memory
> Ian
>> On 10 February 2017 at 13:44, Richard McDonnell <[hidden email]> wrote:
>> Ian,
>> You could try to limit the max amount of ram available for each VM, this would have been done when each, was created, you should probably start there!
>> Its under Settings, System, Motherboard and Base Memory, I would say reduce it so as each VM has equal Memory and you leave a bit for the host.
>> Regards,
>> Richard.
>>> On 09/02/2017 14:26, Neumann, Andreas wrote:
>>> Hi Ian,
>>> You can limit the nr of CPU cores it uses for rendering:
>>> Settings --> Options --> Rendering --> Render layers in parallel / Max cores
>>> I don't think you can limit memory consumption with QGIS settings.
>>> Andreas
>>>> On 2017-02-09 14:31, Ian Turton wrote:
>>>> I know that sounds like something you wouldn't want to do but we have a number of users sharing a VM and if the first QGis started manages to grab all (or even most) of the available memory it prevents the other users from being able to start QGis let alone use it.
>>>> Cheers
>>>> Ian
>>>> Ian Turton
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> [hidden email]
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> [hidden email]
>> Richard McDonnell
>> GIS Specialist PgD GIS AssocSCSI
>> OPW FRM Data Management
>> 52 Stephens Green, Dublin 2.
>> TEL: 01 6476543
>> [hidden email]
> Ian Turton
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Is-there-any-way-to-constrain-the-resources-QGis-uses-tp5307180p5307432.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Is-there-any-way-to-constrain-the-resources-QGis-uses-tp5307180p5307435.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170210/5b11130d/attachment.html>
