[Qgis-user] crs
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Feb 10 07:43:09 PST 2017
Boaz,
Assuming that's the correct CRS,
1. Save the DXF as a Shapefile and specify 4326.
2. Using Reproject Layer, select the newly created shapefile and
specify the 2039 ( I had it wrong in my previous email) in the
*Target CRS* field, by right clicking on the button to the right of
the field and typing 2039 into the search field, and select Israeli TM
3. Under the Reprojected field either leave alone (results in a tempory
File) or pick save to file by right clicking on the little button to
the right of the field
The translated file should be loaded into your desktop.
Hope this helps,
Richard.
On 10/02/2017 15:24, Boaz Bar Ilan wrote:
> the dxf comes ( when I add it) with crs epsg 4326
> I'm trying to change it to EPSG code of 2093
> am I now more clear ? I hope so
> thanks
> boaz
> 2017-02-10 17:17 GMT+02:00 Richard McDonnell <richard.mcdonnell at opw.ie
> <mailto:richard.mcdonnell at opw.ie>>:
> Hey,
> By defined, im looking to see are you using a recognised
> Coordinate reference System (CRS).
> For Example you mention Israeli TM, which has a EPSG code of 2093,
> does your old Grid have a recognised CRS 4141 perhaps???
> Without knowing what CRS of your DXF has its very hard to do
> either of my examples.
> Sorry I cant be of more help!
> Regards,
> Richard.
> On 10/02/2017 14:37, Boaz Bar Ilan wrote:
>> hi
>> thanks
>> I don't know what your mean - defined csr code - I switch to
>> Israel / Israeli TM
>> and I also enable on to fly option. so I couldn't understand
>> your first advice
>> I tried your second advice ( by typing reproject). when I do run
>> I get :
>> Algorithm Reproject layer starting...
>> unknown See log for more details
>> thanks
>> boaz
>> 2017-02-10 15:36 GMT+02:00 Richard McDonnell
>> <richard.mcdonnell at opw.ie <mailto:richard.mcdonnell at opw.ie>>:
>> Hi Boaz,
>> First thing I would say is to save it as a shapefile in its
>> native CRS. Also you dont mention a EPSG Code, are you using
>> a defined or custom CRS?
>> If you are using a defined CRS with a EPSG, you can use on
>> the fly transformations, having the project set to the "New
>> Grid" and your shapefile in its native or "Old grid". This
>> can be done by right clicking on the EPSG: code on the bottom
>> right of QGIS, and ticking *Enable 'on the fly' transformations
>> *The other option would be to use reproject shapefile, to
>> translate the CRS from the old to the new. you can find this
>> by typing reproject into the Processing Toolbox Search, its
>> one of the QGIS geoalgorithims.
>> Regards,
>> Richard.
>> On 10/02/2017 12:27, Boaz Bar Ilan wrote:
>>> hi
>>> I have a dxf file ( converted from dwg ) . its coodinates
>>> are in the old grid.
>>> how can I match it to the new grid ?
>>> whaen I change it in the project property it doesn't work
>>> thanks
>>> boaz
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> -- *_Richard McDonnell_* *GIS Specialist PgD GIS AssocSCSI*
>> *OPW FRM Data Management* *52 Stephens Green, Dublin 2.* TEL:
>> 01 6476543
>> <http://www.opw.ie/>
> -- *_Richard McDonnell_* *GIS Specialist PgD GIS AssocSCSI* *OPW
> FRM Data Management* *52 Stephens Green, Dublin 2.* TEL: 01 6476543
-- *_Richard McDonnell_* *GIS Specialist PgD GIS AssocSCSI* *OPW FRM
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170210/b2a47261/attachment.html>
