[Qgis-user] crs
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Feb 10 06:09:28 PST 2017
I see that Richard has responded correctly. I will just add that dxf files do not really have a CRS. You just need to know it! Usually, the coordinates are in meters or feet and correspond to a local CRS (ex UTM zone 18N). You may have to do some trial and error in order to find the original CRS. When you find that, saving it as a shape file as Richard mentioned, and then specifying the crs, is a good way to go.
Good luck
Nicolas
> Le 10 févr. 2017 à 07:27, Boaz Bar Ilan [via OSGeo.org] <ml-node+s1560n5307405h16 at n6.nabble.com> a écrit :
> hi
> I have a dxf file ( converted from dwg ) . its coodinates are in the old grid.
> how can I match it to the new grid ?
> whaen I change it in the project property it doesn't work
> thanks
> boaz
> Qgis-user mailing list
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/crs-tp5307405.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/crs-tp5307405p5307433.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170210/326ade36/attachment.html>
