[Qgis-user] Fwd: Import and convert points from Google Maps
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Mon Feb 20 12:54:40 PST 2017
The coordinates in your screenshot (-48 -27) seem decimal lat lon
coordinates (wgs84, epsg:4326). Somewhere in the south of Brazil?
Can you provide some coordinates straight from your csv? Just post the
first 2 lines of the csv file.
Raymond
On 20-02-17 14:26, Renato Saboya wrote:
> Dear all:
> I am trying to generate a point shapefile from lat/long coordinates
> obtained from Google Maps' API. They were generated by a WordPress
> plugin (Gravity Forms Geolocation Add-on) and processed in R to generate
> a new CSV file with the latitude and longitude in Y and X columns,
> respectively. I tried to import them to QGIS using "Add delimited text
> layer..." and EPSG 3857, which I found online to be the EPSG of Google
> Maps. I now want to convert this layer / shape to UTM in order to
> integrate it with my other layers.
> The points are created correctly, apparently. When I check their
> coordinates and compare to the ranges of values in Google Maps, they
> seem ok.
> Inline images 1
> However, if I try to load another shapefile of the same location, it
> falls very far from the points. Similarly, If I try to load a map from
> QuickMapServices, it doesn't work: "/QuickMapServices: Failed to
> download all 1 files. - Google Satellite/".
> When I save the point shape to UTM (EPSG 31982) to check the
> coordinates, the values are not coherent with other shapes of the same
> location:
> Converted coordinates:
> Inline images 4
> What the coordinates should look like (approximate values):
> Inline images 5
> I also tried inverting the values of lat / long to x and y, to no avail.
> Any thoughts would be highly appreciated!
> Thanks in advance.
> Regards,
> *Renato T. de Saboya*
> Universidade Federal de Santa Catarina
> Programa de Pós-Graduação em Arquitetura e Urbanismo (PósArq)
> Urbanidades <http://urbanidades.arq.br> | Infoarq
> <http://infoarq.arq.ufsc.br/> | PósArq
> <http://posarq.ufsc.br/renato-t-de-saboya/> | Academia.edu
> <http://ufsc.academia.edu/RenatoSaboya> | ResearchGate
> <http://www.researchgate.net/profile/Renato_Saboya>
> Qgis-user mailing list
