[Qgis-user] Forced raster export
DelazJ
delazj at gmail.com
Tue Feb 21 08:41:52 PST 2017
Hi
Stephen, what happens if you ignore the message and still request for the
export? It should work imo though I'm not that sure the result will match
your expectations. give it a try!
Blended modes might be
http://docs.qgis.org/testing/en/docs/user_manual/introduction/general_tools.html#blending-modes
Given that it's a setting available in almost all configurable items
(layer, feature, label, print composer items) it'd be hard to point you to
a single and right place.
Regards,
Harrissou
2017-02-21 17:11 GMT+01:00 Stephen Wandling <swandling at gmail.com>:
> Hi Richard,
> Yes, I can see my question was not very clear. I do not want a raster
> PDF. Composer has automatically set that option to Print as Raster because
> of "Advanced composition effects" (from the error message), and mentions
> "blended modes" or "vector layer transparency" being enabled.
> I found and removed a transparency set on one component, but that did not
> change the situation. I may have 'blended modes' set, but I do not know
> what they are, so I can not look for them. And, the problem may be some
> other 'advanced composition effect'?
> So, my question is: What must I do to get my map to not export as a Raster?
> Thanks for your response,
> Stephen
> On 21/02/2017 3:34 AM, Richard McDonnell wrote:
>> Hi Stephen,
>> Not exactly sure, but It may be that you need to have the *Print as
>> Raster* option Picked.
>> Its in *Export Settings* under *Composition*.
>> Hope it helps,
>> Regards,
>> Richard.
>> On 20/02/2017 21:38, Stephen Wandling wrote:
>>> I have pulled together data from a few sources for my current map
>>> project. I was getting coordinate issues until I noted the "Set Projet CRS
>>> from Layer" option. So, I have been adding a shape file from the local
>>> Regional District and setting the CRS to that. Then I add other layers.
>>> It seemed to be dealing with my coordinate issues.
>>> But now, when I create my map in Composer, when I go to Save, as a PDF,
>>> I am informed that I have to save as a raster. The notice mentions
>>> 'blended modes' and 'vector layer transparency'. I did have a transparency
>>> set for one layer, which I eliminated, and I do not know what 'blended
>>> modes' might mean, unless it means the 'blended CRS' I have created in my
>>> map?
>>> The raster PDF does not meet my needs.
>>> Stephen
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170221/1266a31b/attachment.html>
