[Qgis-user] Forced raster export
Stephen Wandling
swandling at gmail.com
Tue Feb 21 13:44:06 PST 2017
Harrissou,
I tried ignoring the message. I removed the 'Save as Raster' message,
un-checked the Print as Raster selection (automatically selected by
Composer) and hit Save. This just resulted in the message returning.
I was using a tile from a bigger map as, what I think of as, my
'background' It is an .ecw file and is 6.8 Mb in size. This is a
raster file.
*Q*: Maybe the size of that file is what triggers the message?
*Q*: I am very new to this level of GIS. I suspect my problems may
originate from the cascading menus on the Geogratis site, when I am
seeking their free data. I see a menu with several choices, consisting
primarily of acronyms I do not understand. I choose one and get another
similar menu. This continues for maybe 6 levels. My 'guesses' at any
level seems like it might give me very different results?
Stephen
On 21/02/2017 8:41 AM, DelazJ wrote:
> Hi
> Stephen, what happens if you ignore the message and still request for the
> export? It should work imo though I'm not that sure the result will match
> your expectations. give it a try!
> Blended modes might be
> http://docs.qgis.org/testing/en/docs/user_manual/introduction/general_tools.html#blending-modes
> Given that it's a setting available in almost all configurable items
> (layer, feature, label, print composer items) it'd be hard to point you to
> a single and right place.
> Regards,
> Harrissou
> 2017-02-21 17:11 GMT+01:00 Stephen Wandling<swandling at gmail.com>:
>> Hi Richard,
>> Yes, I can see my question was not very clear. I do not want a raster
>> PDF. Composer has automatically set that option to Print as Raster because
>> of "Advanced composition effects" (from the error message), and mentions
>> "blended modes" or "vector layer transparency" being enabled.
>> I found and removed a transparency set on one component, but that did not
>> change the situation. I may have 'blended modes' set, but I do not know
>> what they are, so I can not look for them. And, the problem may be some
>> other 'advanced composition effect'?
>> So, my question is: What must I do to get my map to not export as a Raster?
>> Thanks for your response,
>> Stephen
>> On 21/02/2017 3:34 AM, Richard McDonnell wrote:
>>> Hi Stephen,
>>> Not exactly sure, but It may be that you need to have the *Print as
>>> Raster* option Picked.
>>> Its in *Export Settings* under *Composition*.
>>> Hope it helps,
>>> Regards,
>>> Richard.
>>> On 20/02/2017 21:38, Stephen Wandling wrote:
>>>> I have pulled together data from a few sources for my current map
>>>> project. I was getting coordinate issues until I noted the "Set Projet CRS
>>>> from Layer" option. So, I have been adding a shape file from the local
>>>> Regional District and setting the CRS to that. Then I add other layers.
>>>> It seemed to be dealing with my coordinate issues.
>>>> But now, when I create my map in Composer, when I go to Save, as a PDF,
>>>> I am informed that I have to save as a raster. The notice mentions
>>>> 'blended modes' and 'vector layer transparency'. I did have a transparency
>>>> set for one layer, which I eliminated, and I do not know what 'blended
>>>> modes' might mean, unless it means the 'blended CRS' I have created in my
>>>> map?
>>>> The raster PDF does not meet my needs.
>>>> Stephen
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170221/2a51ce81/attachment.html>
