[Qgis-user] What does the "Vector Field Marker" symbol layer stand for?
Chris Crook
ccrook at linz.govt.nz
Thu Feb 23 13:29:39 PST 2017
Hi
This is adapted from the Vector Field Renderer plugin - see http://htmlpreview.github.io/?https://github.com/ccrook/QGIS-VectorFieldRenderer-Plugin/blob/master/VectorFieldRenderer/index.html which provides a bit of background. The plugin provides a lot more capability, but you should be able to get the essential idea from here.
Cheers
Chris
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of DelazJ
Sent: Friday, 24 February 2017 12:01 a.m.
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] What does the "Vector Field Marker" symbol layer stand for?
Hi all,
When setting a symbol for a point layer feature, one of the available marker symbol type is "vector field marker". It expects some attributes to be used and some angle/orientation settings but I couldn't figure out what it is about, what is required for the fields and which rendering I should expect.
Thanks to anyone who could shed some lights on this...
Harrissou
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170224/04358847/attachment.html>
