[Qgis-user] What does the "Vector Field Marker" symbol layer stand for?
    DelazJ
    delazj at gmail.com
    Thu Feb 23 15:10:40 PST 2017
Yes, this is more than what I was looking for. Thank you, Chris.
May I pick part of your description to improve the official Documentation?
Regards,
Harrissou
2017-02-23 22:29 GMT+01:00 Chris Crook <ccrook at linz.govt.nz>:
> Hi
> This is adapted from the Vector Field Renderer plugin - see
> http://htmlpreview.github.io/?https://github.com/ccrook/
> QGIS-VectorFieldRenderer-Plugin/blob/master/VectorFieldRenderer/index.html
> which provides a bit of background.  The plugin provides a lot more
> capability, but you should be able to get the essential idea from here.
> Cheers
> Chris
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *DelazJ
> *Sent:* Friday, 24 February 2017 12:01 a.m.
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] What does the "Vector Field Marker" symbol layer
> stand for?
> Hi all,
> When setting a symbol for a point layer feature, one of the available
> marker symbol type is "vector field marker". It expects some attributes to
> be used and some angle/orientation settings but I couldn't figure out what
> it is about, what is required for the fields and which rendering I should
> expect.
> Thanks to anyone who could shed some lights on this...
> Harrissou
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170224/6604a63e/attachment.html>
