[Qgis-user] DWG import
Nyall Dawson nyall.dawson at gmail.com
Sun Jan 1 03:28:36 PST 2017
On 1 January 2017 at 20:25, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Randal,
> On Sat, 31. Dec 2016 at 09:24:54 -0500, Randal Hale wrote:
>> I've been testing the DWG Import - one question. I imported a 3D DWG
>> file and all the data data is imported (yay) but there isn't a
>> elevation attached anywhere.
> It should be in the geometry - >2D isn't used widely in QGIS yet - so that
> isn't visible everywhere.  Did you check the nodetool?
Another option is the identify tool - this will also show z values if
they are present and you click near a node.
Nyall
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
