[Qgis-user] DWG import
Randal Hale
rjhale at northrivergeographic.com
Sun Jan 1 07:06:58 PST 2017
....and there they are. Wow. Good deal - not to play around with this
some more.
Thanks so much for the help.
Randy
On 01/01/2017 06:28 AM, Nyall Dawson wrote:
> On 1 January 2017 at 20:25, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Randal,
>> On Sat, 31. Dec 2016 at 09:24:54 -0500, Randal Hale wrote:
>>> I've been testing the DWG Import - one question. I imported a 3D DWG
>>> file and all the data data is imported (yay) but there isn't a
>>> elevation attached anywhere.
>> It should be in the geometry - >2D isn't used widely in QGIS yet - so that
>> isn't visible everywhere. Did you check the nodetool?
> Another option is the identify tool - this will also show z values if
> they are present and you click near a node.
> Nyall
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
