[Qgis-user] DWG import
Pedro Venâncio
pedrongvenancio at gmail.com
Sun Jan 1 16:08:21 PST 2017
With this Randal's question, I've found something that can be a bug. When I
import the DWG, I can edit the layers created in the geopackage. Then, if I
save the group as Layer Definition File (to preserve the style and
symbology), close QGIS, and then add the QLR with Layer -> Add from Layer
Definition File..., the edit mode (Toggle Editing button) is disabled.
Anyone confirm?
I've tested the same process (save and open as Layer Definition File) with
other layers, and the edit mode works ok.
Thanks.
Best regards,
Pedro Venâncio
2017-01-01 15:06 GMT+00:00 Randal Hale <rjhale at northrivergeographic.com>:
> ....and there they are. Wow. Good deal - not to play around with this some
> more.
> Thanks so much for the help.
> Randy
> On 01/01/2017 06:28 AM, Nyall Dawson wrote:
>> On 1 January 2017 at 20:25, Jürgen E. Fischer <jef at norbit.de> wrote:
>>> Hi Randal,
>>> On Sat, 31. Dec 2016 at 09:24:54 -0500, Randal Hale wrote:
>>>> I've been testing the DWG Import - one question. I imported a 3D DWG
>>>> file and all the data data is imported (yay) but there isn't a
>>>> elevation attached anywhere.
>>> It should be in the geometry - >2D isn't used widely in QGIS yet - so
>>> that
>>> isn't visible everywhere. Did you check the nodetool?
>> Another option is the identify tool - this will also show z values if
>> they are present and you click near a node.
>> Nyall
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> http://www.norbit.de
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170102/98a301a6/attachment.html>
