[Qgis-user] WMS via https - "SSL handshake failed"
Luigi Pirelli luipir at gmail.com
Mon Jan 2 00:52:39 PST 2017
Hi John
SSL is managed storing credentials using the QGIS Authentication
Manager that store credentials in the same way as Firefox, in a master
pwd crypted store in your $home/.qgis2/qgis-auth.db.
You should managed credentials using Settings->options->authentication.
QGIS uses OpenSSL => and specifically can import different king of
credential method (using plugins => can be expanded). De default auth
method installed are listed in the documentation:
https://docs.qgis.org/2.14/en/docs/user_manual/auth_system/auth_overview.html
what is you auth method? can you explain the workflow you followed to
store and use your credentials?
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 29 December 2016 at 22:38, John Cartwright
<john.c.cartwright at comcast.net> wrote:
> Hello All,
> I’m trying to use a WMS service over https and get the following error when trying to connect:
> Failed to download capabilities:
> Download of capabilities failed: SSL handshake failed
> The URL works fine in a browser though.  I’m guessing that QGIS and the server are not able to agree on a cipher suite.  Can anyone tell me what ciphers QGIS supports or any way to get more insight into the underlying problem?
> QGIS is version 2.18.2.
> Thanks!
> —john
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
