[Qgis-user] Custom dash pattern broken when used inside a line pattern fill
    Neumann, Andreas
    a.neumann at carto.net
    Mon Jan  9 05:44:02 PST 2017
In addition it seems like the thicker the custom dashed line is, the
more ugly rendering artefacts appear at the change between a dash and a
space.
Is this a qt bug or a QGIS bug?
Andreas
On 2017-01-09 14:36, Neumann, Andreas wrote:
> Hi,
> My colleague experimented with custom dash patterns inside a line pattern fill. We discovered that this feature is seriously broken, both in 2x and 3x. Both on Windows and Linux.
> We made sure that the cap style is set to "flat" and then applied a custom dash pattern inside a line pattern fill, with equal length (say 3mm length dash, 3mm length space). The result as it appears is more like a longer dash, then a space, then a shorter dash and a space. Certainly not what we defined. If you change to a longer dash, say 20mm dash, 3mm space, the spaces totally disappear.
> Is there maybe a unit problem when rendering custom dashes inside a line pattern? It looks like the total length of the custom dash pattern doesn't equal the sum of the individual dash/space patterns.
> Can others confirm my issue?
> Thanks,
> Andreas
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/ddcb59d2/attachment.html>
