[Qgis-user] Symbolizing a discrete or a boolean raster (Stéphane Henriod)
Pedro Machado Monteiro
pedromachadomonteiro at gmail.com
Wed Jan 11 03:30:22 PST 2017
I totally agree. For a simple user like me, directly retrieving unique
values (like ArcGis does), and having direct access to raster tables, would
be a major step to enhance raster work productivity.
All the best
Pedro Monteiro
2017-01-11 3:55 GMT+00:00 Stéphane Henriod <s at henriod.info>:
> Hi Richard
> this is a nice workaround, that I will also probably use in the future!
> Thanks a lot!
> However, this becomes unhandy:
> - if the raster doesn't contain all values between 1 and 50 (let's
> say, there are only classes 2, 23, 56 and 49) => need to manually remove
> all the unnecessary values
> - if the raster contains a discrete amount of decimal values (2.3, 4.5
> and 12.8)
> - if I don't know in advance the number of classes (which happens
> quite often: I receive a dataset that I don't know much about and want to
> quickly display / style it to explore it)
> All the answers in this thread actually justify (IMO) the feature request:
> it is at the moment possible to style discrete rasters in QGIS but only
> using workarounds that are not necessarily adapted in all cases and that
> are completely untransparent for beginners.
> All the best
> Stéphane
> Le mardi 10 janvier 2017, Richard McDonnell <richard.mcdonnell at opw.ie> a
> écrit :
>> Harrissou,
>> Not sure if this is a solution, or if anyone has already given you this
>> answer, but.... if you know a classified raster has *50* values, which
>> you wish to style individually, you could try setting
>> - *Colour Interpolation* to *Linear*
>> - *Mode *to* Equal Interval*
>> - *Classes *to* 51 *(one more than the Max)
>> I have only just tested this on a raster with 4 values and its worked for
>> me!
>> Hope this helps!
>> Regards,
>> Richard.
>> On 10/01/2017 09:49, DelazJ wrote:
>> Hi Stéphane,
>> 2017-01-10 4:02 GMT+01:00 Stéphane Henriod <s at henriod.info>:
>>> Hi Chris
>>> this is very nice! I indeed didn't know this trick and will certainly
>>> use it again in the future!
>>> However... :-)
>>> I am currently teaching QGIS to beginners and this for sure is not an
>>> appropriate method for them (especially in the case you have to generate
>>> the symbology file through a script)!
>>> Since the user can style continuous rasters with some "button-clicking",
>>> I believe the same option should be available for discrete rasters as well.
>>> I am thus wondering if anyone else than me sees it as a priority for
>>> QGIS? If yes, how to motivate the developers to take it for the next
>>> release and / or how much would such a development cost? (I unfortunately
>>> don't have the competences to do it myself)
>>> There have been some work done in the raster properties dialog in the
>> upcoming 3.0. I don't know if your concern was covered though.
>> If you want, you can move the question to the developer's list
>> <http://qgis.org/en/site/getinvolved/mailinglists.html#qgis-developers-list>
>> and discuss whether/how this can be implemented (and its requirements).
>> Regards,
>> Harrissou
>> Thanks again and cheers!
>>> Stéphane
>>> Le mardi 10 janvier 2017, Chris House <housec01 at gmail.com> a écrit :
>>>> Hi Stéphane,
>>>> I don't know if this is what you are looking for or not but I have a
>>>> method of classifying rasters by color based on a set (standard) colors. I
>>>> created a spreadsheet that has several required columns, value, red, green,
>>>> blue...and you can have an optional field for a display value. So say
>>>> value 1 is water you can use that last column to name that value so that in
>>>> the QGIS layer tree and in legend it says Water instead of value 1.
>>>> save the spreadsheet as a csv and change the extension to .txt instead
>>>> of .csv.
>>>> I then go into the symbology section of the raster choose singleband
>>>> pseudocolor. Use the folder to browse to your text file and click add.
>>>> There is a format for this text file. It is below. If you need me to
>>>> email it I will do that in direct email.
>>>> # QGIS Generated Color Map Export File
>>>> INTERPOLATION:EXACT
>>>> -9999,0,0,0,255,NoData
>>>> 0,176,176,176,255,Non-Forested
>>>> 15,234,255,191,255,10 <= CC < 20
>>>> 25,187,230,149,255,20 <= CC < 30
>>>> 35,140,201,109,255,30 <= CC < 40
>>>> 45,98,176,74,255,40 <= CC < 50
>>>> 55,59,153,43,255,50 <= CC < 60
>>>> 65,0,128,0,255,60 <= CC < 70
>>>> 75,15,92,11,255,70 <= CC < 80
>>>> 85,17,61,12,255,80 <= CC < 90
>>>> 95,16,36,12,255,90 <= CC <= 100
>>>> In my example if I don't assign a value it gets ignored by QGIS. If
>>>> you are wondering how to assign unique colors to say 200 unique
>>>> values...just script it. I have done this and as long as you have the
>>>> number of unique values you want and to make them unique in the script it
>>>> works.
>>>> I hope this helps. I know it isn't a "button" but to be honest I like
>>>> this better. If you already knew this...well then maybe it will help
>>>> someone out in the future.
>>>> --Chris
>>>> On Mon, Jan 9, 2017 at 3:00 PM, <qgis-user-request at lists.osgeo.org>
>>>> wrote:
>>>>> Send Qgis-user mailing list submissions to
>>>>> qgis-user at lists.osgeo.org
>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>> or, via email, send a message with subject or body 'help' to
>>>>> You can reach the person managing the list at
>>>>> qgis-user-owner at lists.osgeo.org
>>>>> When replying, please edit your Subject line so it is more specific
>>>>> than "Re: Contents of Qgis-user digest..."
>>>>> Today's Topics:
>>>>> 1. Re: Symbolizing a discrete or a boolean raster (Stéphane Henriod)
>>>>> Message: 1
>>>>> Date: Mon, 9 Jan 2017 23:07:36 +0600
>>>>> From: Stéphane Henriod <s at henriod.info>
>>>>> To: Enrico Fiore <enricofiore at libero.it>
>>>>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>>>>> Subject: Re: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>> Message-ID:
>>>>> <CAK6pVBXURm_e7dRP+8SP9amPUUX0+Cn3GVxLPNjOHhno85o2rA at mail.gm
>>>>> ail.com>
>>>>> Content-Type: text/plain; charset="utf-8"
>>>>> Hi
>>>>> thanks for following up!
>>>>> It actually does part of the job!
>>>>> Using *Color interpretation: Exact*, I can indeed input the exact
>>>>> values I
>>>>> want to display (1,5 and 10) and all other pixels are hidden.
>>>>> HOWEVER,
>>>>> this still feels like a workaround:
>>>>> - In the case of a discrete raster with many (> 50) unique values,
>>>>> I do
>>>>> not want to input all of them manually
>>>>> - In some cases, I do not know in advance all the unique values of
>>>>> my
>>>>> raster
>>>>> - If I click on *Classify*, QGIS will choose X values (based on the
>>>>> number of classes and the classification method (continuous or equal
>>>>> interval)), which no longer match the "exact" values of my raster.
>>>>> It
>>>>> doesn't really make sense to classify a discrete rendering
>>>>> So I would say, we still need a render type "discrete raster" which
>>>>> offers
>>>>> the function to "retrieve all unique values" (and automatically apply a
>>>>> discrete color ramp)
>>>>> Attached a (fake) test dataset.
>>>>> Thanks and cheers
>>>>> Stéphane
>>>>> Le lundi 9 janvier 2017, Enrico Fiore <enricofiore at libero.it> a écrit
>>>>> > Hi,
>>>>> > Sorry I can't do test, but if you use exact in color interpolation
>>>>> > parameter?
>>>>> > Cheers
>>>>> > Enrico
>>>>> Le lundi 9 janvier 2017, Stéphane Henriod <s at henriod.info> a écrit :
>>>>> > Hi
>>>>> > unfortunately this is doing quite something different!
>>>>> > If I have a raster with 10 Landcover classes (1,2,3,4,5,6,7,8,9,10)
>>>>> and I
>>>>> > want to display only 1,5 and 10, using *Discrete *(1: red, 5:
>>>>> yellow, 10:
>>>>> > blue) the following will happen:
>>>>> > All pixels between 1 and 4 will be red
>>>>> > All pixels between 5 and 9 will be yellow
>>>>> > All pixels with 10 will be blue
>>>>> > In this sense, the pixels are indeed not interpolated, but this
>>>>> still is
>>>>> > not the behavior I am expecting when styling discrete rasters.
>>>>> > A "style discrete raster" function should offer the following:
>>>>> > - Automatically recover all unique values from the raster
>>>>> > - Only display the pixels to which the user has explicitly
>>>>> assigned a
>>>>> > color
>>>>> > But thanks for your hint, this can be helpful in other cases!
>>>>> > Cheers
>>>>> > Stéphane
>>>>> > <javascript:_e(%7B%7D,'cvml','enricofiore at libero.it');>> a écrit :
>>>>> >> Hi,
>>>>> >> I think that the solution is in the QGIS documentation, that you
>>>>> can read
>>>>> >> here:
>>>>> <http://docs.qgis.org/2.14/en/docs/user_manual/working_with_r>
>>>>> >> aster/raster_properties.html#band-rendering
>>>>> >> you have to use *Singleband pseudocolor *and set color
>>>>> interpolation to
>>>>> >> Discrete.
>>>>> >> Enrico
>>>>> >> ----Messaggio originale----
>>>>> >> Da: "Stéphane Henriod" <s at henriod.info>
>>>>> >> Data: 09/01/2017 6.30
>>>>> >> A: "qgis-user"<qgis-user at lists.osgeo.org>
>>>>> >> Ogg: [Qgis-user] Symbolizing a discrete or a boolean raster
>>>>> >> Dear all
>>>>> >> As much as I love QGIS and use it in my everyday life, there is one
>>>>> >> feature that I find particularly annoying: the styling of discrete
>>>>> rasters.
>>>>> >> Basically, if I have a raster layer consisting of discrete landcover
>>>>> >> values (1: water, 2: forest, 3: built-up), it seems that there is
>>>>> no easy
>>>>> >> way to style it. QGIS will assume that the data is continuous and
>>>>> basically
>>>>> >> interpolate the color between each value, which leads to the
>>>>> following
>>>>> >> issues:
>>>>> >> Let's say I want to display only water and built-up (values 1 and
>>>>> 3),
>>>>> >> water in blue and built-up in grey. QGIS will still display the
>>>>> forests,
>>>>> >> using a color somewhere "between" blue and grey. My only left
>>>>> option is to
>>>>> >> process the raster to actually replace all the 2 with NoData, which
>>>>> is
>>>>> >> highly unpractical...
>>>>> >> Same if I have a boolean raster (only 0 and 1 values). QGIS will by
>>>>> >> default make a color ramp from 0 to 0.9999.
>>>>> >> Also, the whole rather feels like a work-around for a missing
>>>>> feature.
>>>>> >> I dream of a feature similar to this one from ArcGIS:
>>>>> >> <http://resources.arcgis.com/en/help/main/10.1/index>
>>>>> http://resources.arcgis.com/en/help/main/10.1/index.
>>>>> >> html#/representing_unique_categories_such_as_land_use/009t00
>>>>> 000074000000/
>>>>> >> where all unique values are styled independently and where I can
>>>>> easily
>>>>> >> skip the values I don't want to see on my map.
>>>>> >> I asked a question here:
>>>>> >> <http://gis.stackexchange.com/questions/194116/qgis-style-a-d>
>>>>> >> iscrete-raster
>>>>> >> and opened a ticket here:
>>>>> >> <http://hub.qgis.org/issues/14845>http://hub.qgis.org/issues/14845
>>>>> >> But none has gotten lots of attention yet... Am I the only one to be
>>>>> >> annoyed by this? If no, please raise your hand and let's try to get
>>>>> some
>>>>> >> momentum and see how to push this feature forward!
>>>>> >> Thanks a lot in advance!
>>>>> >> Cheers
>>>>> >> Stéphane
>>>>> Stéphane Henriod
>>>>> CIM-Expert for GIS and Green Economy Statistics
>>>>> Национальный статистический комитет Кыргызской Республики
>>>>> Кыргыз Республикасынын Улуттук статистика комитети
>>>>> National Statistical Committee of the Kyrgyz Republic
>>>>> 374 Фрунзе ул. / Frunze str.
>>>>> 720033 Бишкек / Bishkek
>>>>> T +996 778 46 99 02 (KG)
>>>>> T +49 176 280 11 050 <+49%20176%2028011050> (DE)
>>>>> E s at henriod.info
>>>>> W http://www.stat.kg
>>>>> W3W: nightfall.into.bucket
>>>>> <https://map.what3words.com/nightfall.into.bucket> //
>>>>> запас.союз.дружный
>>>>> <https://map.what3words.com/запас.союз.дружный>
>>>>> -------------- next part --------------
>>>>> An HTML attachment was scrubbed...
>>>>> URL: <
>>>>> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.html>
>>>>> A non-text attachment was scrubbed...
>>>>> Type: application/zip
>>>>> Desc: not available
>>>>> URL: <
>>>>> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170109/985fd14c/attachment-0001.zip>
>>>>> Subject: Digest Footer
>>>>> _______________________________________________
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>> Unsubscribe: <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>> End of Qgis-user Digest, Vol 131, Issue 13
>>> Stéphane Henriod
>>> E s at henriod.info
>>> запас.союз.дружный
>>> <https://map.what3words.com/%D0%B7%D0%B0%D0%BF%D0%B0%D1%81.%D1%81%D0%BE%D1%8E%D0%B7.%D0%B4%D1%80%D1%83%D0%B6%D0%BD%D1%8B%D0%B9>
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> *Richard McDonnell*
>> *GIS Specialist PgD GIS AssocSCSI*
>> *OPW FRM Data Management*
>> *52 Stephens Green, Dublin 2.*
>> TEL: 01 6476543
>> <http://www.opw.ie/>
> Stéphane Henriod
> E s at henriod.info
> <https://map.what3words.com/nightfall.into.bucket> // запас.союз.дружный
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170111/5b8d249c/attachment.html>
