[Qgis-user] Load Style from database dialog is blank
Luigi Pirelli
luipir at gmail.com
Fri Jan 13 00:44:21 PST 2017
As noticed in dev list, that part of code has a lack of detailed error
message, and community is working on it. In the meanwhile, I can only
suggest to:
1) check log panel
2) check server messages
3) use a qgis "with debug" version and setup QGIS_DEBUG var to see more messages
probably the point 2 is enough
btw from a postgres client, try the same query done by the postgres provider:
https://github.com/qgis/QGIS/blob/master/src/providers/postgres/qgspostgresprovider.cpp#L4544
look in the same code for saveStyle method to understand how the table
is created.
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 13 January 2017 at 03:23, Tony Bazeley <tonyb at sa.apana.org.au> wrote:
> Hi,
> I'm having some trouble attempting to work with styles in postgresql.
> I can successfully save a style to the database - table layer_styles is
> created and populated.
> But attempting to load brings up the 'Load Style from database dialog' with
> messages "No styles found in database'
> Am using QGIS 2.18.2 with postgresql 9.6 and postgis 2.3
> Would appreciate any thoughts on how to progress.
> Thanks
> Tony
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
