[Qgis-user] Applying cumulative usage to road sections
rossnixon
rossnixon at gmail.com
Sun Jan 15 13:07:04 PST 2017
I don't know if the following can be solved with a QGIS plugin. In MapInfo it
requires a 1500 Euro add-on.
But perhaps someone has had a similar problem in the past? Maybe with road
networks, or watercourse volumes?
I would like to calculate the total 'weight' of goods which will travel
across *each* road section.
Goods will arrive at the closest road section, and then travel along
subsequent road sections to the destination. So, road sections nearest the
destination will have multiple loads travelling over it which need to be
added together. Example image attached.
<http://osgeo-org.1560.x6.nabble.com/file/n5303505/road_usage_problem.jpg>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Applying-cumulative-usage-to-road-sections-tp5303505.html
Sent from the QGIS - User mailing list archive at Nabble.com.
