[Qgis-user] can't editing view using rules
Luca Lanteri lklanteri at gmail.com
Wed Jan 18 00:32:11 PST 2017
Hi Karl,
I've tried to run the same way but also my views are complex and I've a
huge number of view so it's a big deal to change all my views.
I think the issue should be considered a regression.
I've seen that the ticket was automatically assigned to Jurgen Fisher by
the system, I think as PostGIS Data Provider maintenancer.
I Hope to have some news.
Thanks
Luca
2017-01-18 9:11 GMT+01:00 Karl-Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se>:
> Hi again!
> I’ve made some more testing. By adding a RETURNING clause to the rule I
> succeeded to insert features. But since it appears that the RETURNING
> clause has to return all the attributes in the view and my view is complex
> and consists of attributes from several tables I couldn’t just add
> RETURNING * (It will just return the attributes from the table inserted
> into). I had to list all fields in right order, make some attributes up and
> cast them to the right data type. Like this:
> CREATE OR REPLACE RULE lekplatsredskap_ins AS
>     ON INSERT TO park.v_lekplatsredskap DO INSTEAD  INSERT INTO
> park.skotselpunkt (kod, antal, inkopsar, fabrikat, nr, fritext, utforare,
> geom)
>   VALUES (new.kod, new.antal, new.inkopsar, new.fabrikat, new.nr,
> new.fritext, new.utforare, new.geom)
>   RETURNING skotselobj_id,1,kod, 'text'::character
> varying,1234,4567,'plkod'::text, antal, inkopsar, fabrikat, nr,
> fritext,utforare,'2017-01-18'::date,'b_resultat'::character
> varying,'status'::character varying,geom ;
> Please let me know if you find a way to solve this better or a way to turn
> this feature off in QGIS.
> *Karl-Magnus Jönsson*
> *Från:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För *Karl-Magnus
> Jönsson
> *Skickat:* den 17 januari 2017 17:32
> *Till:* Luca Lanteri
> *Kopia:* qgis-user
> *Ämne:* Re: [Qgis-user] can't editing view using rules
> Could it be connected with the new feature to "execute expressions on the
> server side if possible"? Then you should get the new primay key from the
> database before you save edits so you can use it for childs in subforms etc.
> /Karl-Magnus
> 17 jan 2017 kl. 11:16 skrev Luca Lanteri <lklanteri at gmail.com>:
> This is the postgres log [0]:
> In fact the 2.18 query add a RETURNING clause that is non present in QGIS
> 2.14
> I've just opened this ticket: http://hub.qgis.org/issues/16083
> Luca
> [0]
> With QGIS 2.18
> 2017-01-17 11:09:32 CET [25093]: [5-1] user=l_lanteri,db=sigeo,app=QGIS
> STATEMENT:  INSERT INTO "sicod"."v_dif_spon"("geom","
> oper_id","padr_id","sigla_rile","cod_opera","prog_opera"
> ,"localita","sponda","alt_min","alt_max","lung","tipologia",
> "efficienza","stato","mat_massi","mat_c_secc","mat_c_
> int","mat_a_secc","mat_a_int","mat_gabbio","mat_cls","mat_
> legna","i_manuten","i_nessuna","i_prolung","i_pulizia","i_
> ricostru","i_sottomur","i_svuotam","so_dissest","so_
> interra","so_scalzat","so_sifonat","data_rilev","note","
> utente_crea","data_crea","utente_mod","data_mod","fonte"
> ,"desc_fonte","font_elab","font_sopr","font_altro") VALUES
> (st_multi(st_geomfromwkb($1::bytea,32632)),$2,NULL,NULL,
> NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,'0',NULL,'
> 0',NULL,'0','0','0',NULL,'0','0','0','0','0','0','0','0','0'
> ,'0','0','2000-01-01',NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL)
> RETURNING "oper_id"
> With QGIS 2.14
> 2017-01-17 11:12:01 CET [26026]: [3-1] user=l_lanteri,db=sigeo,app=QGIS
> LOG:  execute addfeatures: INSERT INTO "sicod"."v_dif_spon"("geom","
> 2017-01-17 10:41 GMT+01:00 Karl-Magnus Jönsson <Karl-Magnus.Jonsson@
> kristianstad.se>:
> Hi!
> Ok. When I try another view with an INSERT rule I have the same problem in
> 2.18.2. Works in 2.14. UPDATE and DELETE are ok as well. Can we check the
> resulting SQL from QGIS? Must be some difference there. I don’t know if we
> can turn on logging on our database.
> *Från:* mescal72 at gmail.com [mailto:mescal72 at gmail.com] *För *Luca Lanteri
> *Skickat:* den 16 januari 2017 14:44
> *Till:* Karl-Magnus Jönsson
> *Kopia:* qgis-user
> Hi Magnus, thanks for the answer.
> I think my rules are ok also because they work fine with QGIS 2.14.
> The strange things is that the error say about an "INSERT RETURNING" when
> I don't need any RETURING clause.
> The problem happens only with INSERT rules. UPDATE and DELETE are ok.
> this is my INSERT rule:
> CREATE OR REPLACE RULE dif_spon_insert AS
>     ON INSERT TO sicod.v_dif_spon DO INSTEAD  INSERT INTO sicod.dif_spon
> (padr_id, sigla_rile, prog_opera, localita, sponda, alt_min, alt_max, lung,
> tipologia, efficienza, stato, mat_massi, mat_c_secc, mat_c_int, mat_a_secc,
> mat_a_int, mat_gabbio, mat_cls, mat_legna, i_manuten, i_nessuna, i_prolung,
> i_pulizia, i_ricostru, i_sottomur, i_svuotam, so_dissest, so_interra,
> so_scalzat, so_sifonat, note, data_rilev, desc_fonte, font_elab, font_sopr,
> font_altro, geom)
>   VALUES (new.padr_id, new.sigla_rile, new.prog_opera, new.localita,
> new.sponda, new.alt_min, new.alt_max, new.lung, new.tipologia,
> new.efficienza, new.stato, new.mat_massi, new.mat_c_secc, new.mat_c_int,
> new.mat_a_secc, new.mat_a_int, new.mat_gabbio, new.mat_cls, new.mat_legna,
> new.i_manuten, new.i_nessuna, new.i_prolung, new.i_pulizia, new.i_ricostru,
> new.i_sottomur, new.i_svuotam, new.so_dissest, new.so_interra,
> new.so_scalzat, new.so_sifonat, new.note, new.data_rilev, new.desc_fonte,
> new.font_elab, new.font_sopr, new.font_altro, new.geom);
> 2017-01-16 7:56 GMT+01:00 Karl-Magnus Jönsson <Karl-Magnus.Jonsson@
> kristianstad.se>:
> Hi!
> Are you sure it isn’t an issue with the view? I have a view with rules and
> it work in 2.18. When you have conditions in the rule you must have another
> rule on the same event that is unconditional. Check the last paragraph in
> the description : https://www.postgresql.org/docs/current/static/sql-
> createrule.html
> In my case I have a unconditional rule that does nothing:
> CREATE OR REPLACE RULE v_prislistor_upd_ins AS
>     ON UPDATE TO park.v_prislistor
>    WHERE old.id IS NULL DO INSTEAD  INSERT INTO park.priser (kod, pris,
> utforare)
>   VALUES (new.kod, new.pris, new.utforare);
> CREATE OR REPLACE RULE v_prislistor_upd_nothing AS
>     ON UPDATE TO park.v_prislistor DO INSTEAD NOTHING;
> CREATE OR REPLACE RULE v_prislistor_upd_upd AS
>    WHERE old.id IS NOT NULL DO INSTEAD  UPDATE park.priser SET pris =
> new.pris
>   WHERE priser.id = old.id;
> *Från:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *För *Luca
> Lanteri
> *Skickat:* den 13 januari 2017 16:39
> *Till:* qgis-user
> *Ämne:* [Qgis-user] can't editing view using rules
> Hi to all,
> starting fron QIS 2.16 I can't edit anymore postgres views with rules.
> When I try to insert a new feature I have this error [0]. All works fine
> with QGIS 2.14
> Can anyone confirm the issue ?
> Thanks
> Luca
> [0]
> Impossibile applicare le modifiche al vettore v_frane_pol_full
> Errori: ERRORE: 1 geometria non aggiunta.
> Errori della sorgente dati:
> Errore PostGIS nell'aggiunta delle geometrie: ERROR: cannot perform INSERT
> RETURNING on relation "v_frane_pol_full"
> HINT: You need an unconditional ON INSERT DO INSTEAD rule with a RETURNING
> clause.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170118/09c3c11b/attachment.html>
