[Qgis-user] Legend block behaviour in composer
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Jan 27 02:17:15 PST 2017
As a follow up, might I suggest another option, create the legend Block
items as you wish
Export the legend blocks as an image and insert .
This will of course mean that if you restyle the layer you will have to
redo the image, but its another option to try.
Regards,
Richard.
On 27/01/2017 00:49, Nyall Dawson wrote:
> On 27 January 2017 at 09:25, Laurence Béchet <bechet.laurence at gmail.com> wrote:
>> Hi,
>> I have several blocks of legend in my composer that I group together to have
>> a final nice display:
>> https://dl.dropboxusercontent.com/u/92195218/legend.jpg
>> To do so I have to stretch each block so that the final version looks like
>> one single block and not several blocks put together:
>> https://dl.dropboxusercontent.com/u/92195218/legendORG.jpg
>> A very annoying thing is that each time I refresh the composer, my legends
>> get refreshed to their original rectangle and I have to reshape everything
>> ... I thought that if I locked the blocks they would not get refreshed - but
>> they do. I also tried to group them, but again they get refreshed. Is there
>> a way to keep the final shape?
> Uncheck "resize to fit contents" under the legend item properties,
> "main properties" section.
>> Also it took me a while to discover that to pick up several blocks one by
>> one you need to use the shift key and not the control key (as in most
>> software). Is it normal or is it something I can configure somewhere?
> Shift is the standard used in layout/illustration packages. Ctrl
> clicking cycles through selecting overlapping elements.
> Nyall
> Qgis-user mailing list
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170127/29e83465/attachment.html>
