[Qgis-user] Plugin Installation Issue: OpenLayers &
Matthias Kuhn
matthias at opengis.ch
Mon Jul 3 10:37:55 PDT 2017
1. Better use QuickMapServices (or even better the integrated XYZ
possibilities through the browser)
2. Check your proxy settings
On 7/3/17 7:08 PM, Nate Cousineau wrote:
> Here is the message from the log right after the installation failed:
> 2017-07-03T13:07:33 1 Network request
> http://plugins.qgis.org/plugins/openlayers_plugin/version/1.4.3/download/
> timed out
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Matthias Kuhn
> *Sent:* Monday, July 03, 2017 12:47 PM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Plugin Installation Issue: OpenLayers &
> Hi Nate,
> The error message here is unrelated to the two plugins you mentioned.
> Can you go to the plugin manager, make sure these plugins are
> activated and check if you have any other message there?
> Regards
> Matthias
> On 7/3/17 3:40 PM, Nate Cousineau wrote:
> I am using QGIS 2.18.10 on Windows. Below is the error message
> from the log:
> 2017-07-03T09:39:03 1 Failed to load
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll (Reason:
> Cannot load library
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll: The
> specified module could not be found.)
> Sorry for not providing enough information initially. I am new to
> all this.
> Thanks,
> cid:662EF3C8-BB6C-426B-81CE-D65E482964E4 at hsd1.fl.comcast.net.
> *Nate Cousineau*
> Program Officer
> www.quantumfnd.org <http://www.quantumfnd.org/>
> 561-832-7497
> 2701 N. Australian Ave., Suite 200
> West Palm Beach, FL 33407
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On
> Behalf Of Richard Duivenvoorde
> Sent: Sunday, July 02, 2017 4:05 AM
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Plugin Installation Issue: OpenLayers &
> On 30-06-17 21:33, Nate Cousineau wrote:
> > Greetings,
> > I keep receiving an error when trying to install either OpenLayers
> > Plugin or QuickMap Services. Any advice is greatly appreciated.
> Start with telling us which versions of QGIS en Operating System
> your are working with.
> AND what exactly 'an error' means: copy paste the error message
> you see for example
> without this info we can not help you.
> Regards,
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170703/e39694c4/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170703/e39694c4/attachment.jpg>
