[Qgis-user] Plugin Installation Issue: OpenLayers &
Matthias Kuhn
matthias at opengis.ch
Mon Jul 3 10:53:52 PDT 2017
Somehow, your QGIS is not able to download the plugin. This means
something with your internet connection prevents it from doing so
(because I just verified that the link from your own log message works
for me here, so we cannot blame the QGIS plugin repository server).
Let's investigate...
1. Can you download this link from your browser?
http://plugins.qgis.org/plugins/openlayers_plugin/version/1.4.3/download/
If yes, it means your browser can download the plugin (through the same
internet connection).
If no... you'll have to find out why (or download it somewhere else and
do some manual steps)...
Anyway, so if yes you were able to download it: A common difference
between QGIS and your browser is the "proxy". Check the proxy settings
in your browser (depends on your particular browser, use your favorite
search engine...) and then read the following link:
https://gis.stackexchange.com/questions/25188/how-to-access-qgis-plugin-repositories-from-behind-a-proxy
Good luck :)
On 7/3/17 7:44 PM, Nate Cousineau wrote:
> That one isn’t working either – and I’m getting the same error message.
> Apologies again as I’m completely new to this, but what is the
> integrated XYZ possibilities? And what proxy settings am I looking to
> change?
> Thanks,
> Nate
> *From:*Matthias Kuhn [mailto:matthias at opengis.ch]
> *Sent:* Monday, July 03, 2017 1:38 PM
> *To:* Nate Cousineau; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Plugin Installation Issue: OpenLayers &
> 1. Better use QuickMapServices (or even better the integrated XYZ
> possibilities through the browser)
> 2. Check your proxy settings
> On 7/3/17 7:08 PM, Nate Cousineau wrote:
> Here is the message from the log right after the installation failed:
> 2017-07-03T13:07:33 1 Network request
> timed out
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On
> Behalf Of *Matthias Kuhn
> *Sent:* Monday, July 03, 2017 12:47 PM
> *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Hi Nate,
> The error message here is unrelated to the two plugins you mentioned.
> Can you go to the plugin manager, make sure these plugins are
> activated and check if you have any other message there?
> Regards
> Matthias
> On 7/3/17 3:40 PM, Nate Cousineau wrote:
> I am using QGIS 2.18.10 on Windows. Below is the error message
> from the log:
> 2017-07-03T09:39:03 1 Failed to load
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll
> (Reason: Cannot load library
> C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll: The
> specified module could not be found.)
> Sorry for not providing enough information initially. I am new
> to all this.
> Thanks,
> cid:662EF3C8-BB6C-426B-81CE-D65E482964E4 at hsd1.fl.comcast.net.
> *Nate Cousineau*
> Program Officer
> www.quantumfnd.org <http://www.quantumfnd.org/>
> 561-832-7497
> 2701 N. Australian Ave., Suite 200
> West Palm Beach, FL 33407
> -----Original Message-----
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On
> Behalf Of Richard Duivenvoorde
> Sent: Sunday, July 02, 2017 4:05 AM
> To: qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Plugin Installation Issue: OpenLayers &
> On 30-06-17 21:33, Nate Cousineau wrote:
> > Greetings,
> > I keep receiving an error when trying to install either
> OpenLayers
> > Plugin or QuickMap Services. Any advice is greatly appreciated.
> Start with telling us which versions of QGIS en Operating
> System your are working with.
> AND what exactly 'an error' means: copy paste the error
> message you see for example
> without this info we can not help you.
> Regards,
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170703/2f59f45a/attachment.html>
