[Qgis-user] Plugin Installation Issue: OpenLayers &
Nate Cousineau
Nate at quantumfnd.org
Mon Jul 3 11:07:42 PDT 2017
I’m getting a network error when trying to download it via the browser as well. I will check with our IT service provider to see if they have any insights. Thanks so much for all you help!
From: Matthias Kuhn [mailto:matthias at opengis.ch]
Sent: Monday, July 03, 2017 1:54 PM
To: Nate Cousineau
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Plugin Installation Issue: OpenLayers &
Somehow, your QGIS is not able to download the plugin. This means something with your internet connection prevents it from doing so (because I just verified that the link from your own log message works for me here, so we cannot blame the QGIS plugin repository server).
Let's investigate...
1. Can you download this link from your browser?
http://plugins.qgis.org/plugins/openlayers_plugin/version/1.4.3/download/
If yes, it means your browser can download the plugin (through the same internet connection).
If no... you'll have to find out why (or download it somewhere else and do some manual steps)...
Anyway, so if yes you were able to download it: A common difference between QGIS and your browser is the "proxy". Check the proxy settings in your browser (depends on your particular browser, use your favorite search engine...) and then read the following link:
https://gis.stackexchange.com/questions/25188/how-to-access-qgis-plugin-repositories-from-behind-a-proxy
Good luck :)
On 7/3/17 7:44 PM, Nate Cousineau wrote:
[X]
That one isn’t working either – and I’m getting the same error message.
Apologies again as I’m completely new to this, but what is the integrated XYZ possibilities? And what proxy settings am I looking to change?
Thanks,
Nate
Sent: Monday, July 03, 2017 1:38 PM
To: Nate Cousineau; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
1. Better use QuickMapServices (or even better the integrated XYZ possibilities through the browser)
2. Check your proxy settings
On 7/3/17 7:08 PM, Nate Cousineau wrote:
Here is the message from the log right after the installation failed:
2017-07-03T13:07:33 1 Network request http://plugins.qgis.org/plugins/openlayers_plugin/version/1.4.3/download/ timed out
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
Sent: Monday, July 03, 2017 12:47 PM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Nate,
The error message here is unrelated to the two plugins you mentioned.
Can you go to the plugin manager, make sure these plugins are activated and check if you have any other message there?
Regards
Matthias
On 7/3/17 3:40 PM, Nate Cousineau wrote:
I am using QGIS 2.18.10 on Windows. Below is the error message from the log:
2017-07-03T09:39:03 1 Failed to load C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll (Reason: Cannot load library C:/PROGRA~1/QGIS2~1.18/apps/qgis/plugins/globeplugin.dll: The specified module could not be found.)
Sorry for not providing enough information initially. I am new to all this.
Thanks,
[cid:662EF3C8-BB6C-426B-81CE-D65E482964E4 at hsd1.fl.comcast.net.]
Nate Cousineau
Program Officer
www.quantumfnd.org<http://www.quantumfnd.org/>
561-832-7497
2701 N. Australian Ave., Suite 200
West Palm Beach, FL 33407
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Richard Duivenvoorde
Sent: Sunday, July 02, 2017 4:05 AM
On 30-06-17 21:33, Nate Cousineau wrote:
> Greetings,
> I keep receiving an error when trying to install either OpenLayers
> Plugin or QuickMap Services. Any advice is greatly appreciated.
Start with telling us which versions of QGIS en Operating System your are working with.
AND what exactly 'an error' means: copy paste the error message you see for example
without this info we can not help you.
Regards,
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170703/109e5d03/attachment.html>
