[Qgis-user] ilike-operator
Alexandre Neto
senhor.neto at gmail.com
Sat Jul 29 22:40:29 PDT 2017
You can use the "in" operator [0] , together with the lower() function [1].
lower("Shape") in ('rectangle', 'triangle')
Hope it helps,
Alexandre Neto
[0] -
http://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/expression.html#operators
[1] -
http://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/expression.html#string-functions
A sex, 28/07/2017, 13:05, Walter Nordmann <wnordmann at gmx.de> escreveu:
> please try it. it does work! qgis filter is usually accepting all valid
> sql queries.
> filter: lower("value") similar to '(berlin|london|paris)'
> https://wambachers-osm.website/images/osm/snaps_2017/similar.png
> ok, havin problems with hstore, but that's is another question.
> regards
> walter
> Am 28.07.2017 um 13:31 schrieb "Torben Keßler":
> Thanks! Just erased the wildchars to shorten the code.
> I forgot to mention that I'm trying this as a QGIS (v 2.18.7) filter, not
> in ProstgreSQL. There, I have only "ilike" as suitable string operator, it
> seems.
> Best,
> Torben
> Qgis-user mailing list
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170730/4b1abf1d/attachment.html>
