[Qgis-user] QGIS
Randal Hale
rjhale at northrivergeographic.com
Fri Jun 2 12:51:07 PDT 2017
Hey Zachary - you should be able to right click that text file in your
Layers Panel and select "Save As" - save it as a shapefile. You should
then be able to edit that file and delete the points.
Randy
-----Original Message-----
Date: Fri, 2 Jun 2017 19:11:40 +0000
Subject: [Qgis-user] QGIS
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
From: "Young, Zachary" <zyoun462 at live.kutztown.edu>
<!-- P {margin-top:0;margin-bottom:0;} -->
I loaded vector data of points onto the map provided by QGIS (Google
Street). The points were originally created in an Excel file. I then
converted this into a text file because it said to do so. I want to
remove some of these points because they are not all
needed but when ever i click on the layer to highlight it then pencil
goes gray and does not let me edit anything. Please help.
-Zach
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
https://www.northrivergeographic.com
(423) 653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170602/7faf6cd6/attachment.html>
