[Qgis-user] [QGIS-Developer] Geodesic Measure Tool With Bearing	Information
    Neumann, Andreas
    a.neumann at carto.net
    Mon Jun 12 01:43:52 PDT 2017
+1 for getting these improvements in QGIS core, rather than in a plugin.
fyi: https://map.geo.admin.ch/ has an interesting "all-in-one" measure
tool, which could server as an inspiration for QGIS.
If you start with a new measure line, you first get a circle with
distance and bearing. It also shows markers with labels along the line
with round distances (e.g. 500m, 1000m, etc.). If you close the polygon
by going back to the first vertex, it autosnaps and shows the area. So
it is really just one single tool, but it helps to show distances,
bearings and areas - along with an elevation profile.
Greetings,
Andreas
On 2017-06-12 10:27, Nyall Dawson wrote:
> On 10 June 2017 at 02:30, C Hamilton <adenaculture at gmail.com> wrote:
>> Several weeks ago I had proposed a geodesic measure tool that also includes
>> the bearing from point A to B and bearing from B to A. Nyall suggested that
>> this capability be added to the QGIS measure tool. The question is would you
>> want this with the QGIS measure tool or should it be a separate plugin?
> My strong vote would be towards extending the QGIS measure tool. To me
> that's a better solution then requiring users to download a plugin,
> and having to reimplement all the (complex) logic of the measure tool
> again in a python plugin.
>> 1. Where the current measure tool has 'Segments' there would be two more
>> columns with 'Bearing to' and 'Bearing from'.
> Sounds good!
>> 2. I would like to see a check box or selection widget of some sort that
>> chooses between using Geodesic math or the current method of calculating the
>> distances which I am still unsure on how it is doing its calculations.
> If you expand down the info box you'll get a detailed description of
> exactly how QGIS is calculating the distances. Is there something
> missing there?
>> Right now it could use the Vincinty algorithms in QGIS to calculate the
>> distances, but eventually I would like to see the geographiclib algorithms
>> used.
> I'd start with the bearing changes (since they are self contained, and
> the methods for calculating bearing are already present in the QGIS
> api). Then using geographiclib could be discussed as a separate set of
> changes, to be decided on its own merit. If you mix these two changes
> it's likely to get bogged down as one or other part of the changes are
> debated.
>> If this is of interest then I will attempt to get a QGIS development
>> environment running to help make the changes to the core measure tool;
>> otherwise, I will just create a plugin to do this. If I create a plugin I
>> will use the geographiclib python library to do the calculations.
>> Thoughts?
> Go the core! Let us know if you need help setting up a dev
> environment. It's actually much easier for 3.0 then it was for 2.x
> (especially on windows).
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170612/9c656229/attachment.html>
