[Qgis-user] QGIS3 crashes when Open data source manager - Spatialite - New
Zizi Jama mazizi.jama at gmail.com
Tue Jun 20 06:03:46 PDT 2017
Here is the backtrace
#0  __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:58
#1  0x00007faaf4d6437a in __GI_abort () at abort.c:89
#2  0x0000559c46e00453 in qgisCrash(int) ()
#3  <signal handler called>
#4  0x00007faae2e79115 in XChangeProperty () from
/usr/lib/x86_64-linux-gnu/libX11.so.6
#5  0x00007faae2e96da9 in XSetTransientForHint () from
#6  0x00007faacf16d792 in ?? () from
/usr/lib/x86_64-linux-gnu/qt5/plugins/platformthemes/libqgtk3.so
#7  0x00007faacf170291 in ?? () from
#8  0x00007faaf67d49c0 in QDialogPrivate::setNativeDialogVisible(bool) ()
from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#9  0x00007faaf67e70d2 in QFileDialog::setVisible(bool) () from
#10 0x00007faaf67d58f1 in QDialog::exec() () from
#11 0x00007faaf67e7925 in QFileDialog::getOpenFileUrl(QWidget*, QString
const&, QUrl const&, QString const&, QString*, QFlags<QFileDialog::Option>,
QStringList const&) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#12 0x00007faaf67e79ee in QFileDialog::getOpenFileName(QWidget*, QString
const&, QString const&, QString const&, QString*,
QFlags<QFileDialog::Option>) () from
#13 0x00007faa41f0c522 in
QgsSpatiaLiteSourceSelect::newConnection(QWidget*) ()
   from /home/sindile/apps/qgis3/lib/qgis/plugins/libspatialiteprovider.so
#14 0x00007faa41f0c1f4 in QgsSpatiaLiteSourceSelect::on_btnNew_clicked() ()
#15 0x00007faa41f19291 in
QgsSpatiaLiteSourceSelect::qt_static_metacall(QObject*, QMetaObject::Call,
int, void**) ()
#16 0x00007faa41f19616 in
QgsSpatiaLiteSourceSelect::qt_metacall(QMetaObject::Call, int, void**) ()
#17 0x00007faaf593b644 in QMetaObject::activate(QObject*, int, int, void**)
() from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#18 0x00007faaf66cfc12 in QAbstractButton::clicked(bool) () from
#19 0x00007faaf66cfe64 in ?? () from
#20 0x00007faaf66d1257 in ?? () from
#21 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
#22 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
#23 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
QEvent*) ()
#24 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
#25 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) () from
/home/sindile/apps/qgis3/lib/libqgis_core.so.2.99.0
#26 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#27 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) ()
#28 0x00007faaf66490f6 in ?? () from
#29 0x00007faaf664bb03 in ?? () from
#30 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
QEvent*) ()
#31 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
#32 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) () from
#33 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
#34 0x00007faaf5e53723 in
QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)
   from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
---Type <return> to continue, or q <return> to quit---
#35 0x00007faaf5e552a5 in
QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*)
#36 0x00007faaf5e3323b in
QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#37 0x00007faad2513830 in ?? () from
/usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#38 0x00007faaebe89377 in g_main_context_dispatch () from
/lib/x86_64-linux-gnu/libglib-2.0.so.0
#39 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#40 0x00007faaebe8968c in g_main_context_iteration () from
#41 0x00007faaf5963f0f in
QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
#42 0x00007faaf590d88a in
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) ()
#43 0x00007faaf67d5a07 in QDialog::exec() () from
#44 0x00007faaf8d4f967 in QgisApp::dataSourceManager(QString) () from
/home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
#45 0x00007faaf8d5299c in
QgisApp::createActions()::{lambda()#11}::operator()() const ()
   from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
#46 0x00007faaf8db9bbd in QtPrivate::FunctorCall<QtPrivate::IndexesList<>,
QtPrivate::List<>, void,
QgisApp::createActions()::{lambda()#11}>::call({lambda()#11}&, void**) ()
#47 0x00007faaf8db8f89 in void
QtPrivate::Functor<QgisApp::createActions()::{lambda()#11},
0>::call<QtPrivate::List<>, void>({lambda()#11}&, void*, {lambda()#11}&*)
() from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
#48 0x00007faaf8db760c in
QtPrivate::QFunctorSlotObject<QgisApp::createActions()::{lambda()#11}, 0,
QtPrivate::List<>, void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*,
void**, bool*) () from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
#49 0x00007faaf593b81e in QMetaObject::activate(QObject*, int, int, void**)
#50 0x00007faaf65e0992 in QAction::triggered(bool) () from
#51 0x00007faaf65e3380 in QAction::activate(QAction::ActionEvent) () from
#52 0x00007faaf66d11fd in ?? () from
#53 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
#54 0x00007faaf679d66a in QToolButton::mouseReleaseEvent(QMouseEvent*) ()
#55 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
#56 0x00007faaf679d749 in QToolButton::event(QEvent*) () from
#57 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
QEvent*) ()
#58 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
#59 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) () from
#60 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
#61 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
#62 0x00007faaf66490f6 in ?? () from
#63 0x00007faaf664bb03 in ?? () from
#64 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
QEvent*) ()
#65 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
#66 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) () from
#67 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
#68 0x00007faaf5e53723 in
#69 0x00007faaf5e552a5 in
#70 0x00007faaf5e3323b in
#71 0x00007faad2513830 in ?? () from
#72 0x00007faaebe89377 in g_main_context_dispatch () from
#73 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#74 0x00007faaebe8968c in g_main_context_iteration () from
#75 0x00007faaf5963f0f in
#76 0x00007faaf590d88a in
#77 0x00007faaf5915ffc in QCoreApplication::exec() () from
#78 0x0000559c46e06326 in main ()
On Tue, Jun 20, 2017 at 1:31 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Zizi,
> On Mon, 19. Jun 2017 at 20:11:53 +0200, Zizi Jama wrote:
> > QGIS died on signal 11Could not attach to process.  If your uid matches
> the
> > uid of the target
> Reading that instantly causes a strong urge to point at
> http://qgis.org/en/site/getinvolved/development/
> bugreporting.html#creating-a-backtrace
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170620/b8698b7b/attachment.html>
