[Qgis-user] QGIS3 crashes when Open data source manager - Spatialite - New
    Zizi Jama
    mazizi.jama at gmail.com
    Tue Jun 20 07:15:46 PDT 2017
I also get a similar behaviour when
Open data source manager - Delimited Text - Browse
On Tue, Jun 20, 2017 at 3:03 PM, Zizi Jama <mazizi.jama at gmail.com> wrote:
> Here is the backtrace
> #0  __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:58
> #1  0x00007faaf4d6437a in __GI_abort () at abort.c:89
> #2  0x0000559c46e00453 in qgisCrash(int) ()
> #3  <signal handler called>
> #4  0x00007faae2e79115 in XChangeProperty () from
> /usr/lib/x86_64-linux-gnu/libX11.so.6
> #5  0x00007faae2e96da9 in XSetTransientForHint () from
> #6  0x00007faacf16d792 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
> plugins/platformthemes/libqgtk3.so
> #7  0x00007faacf170291 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
> #8  0x00007faaf67d49c0 in QDialogPrivate::setNativeDialogVisible(bool) ()
> from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #9  0x00007faaf67e70d2 in QFileDialog::setVisible(bool) () from
> #10 0x00007faaf67d58f1 in QDialog::exec() () from
> #11 0x00007faaf67e7925 in QFileDialog::getOpenFileUrl(QWidget*, QString
> const&, QUrl const&, QString const&, QString*, QFlags<QFileDialog::Option>,
> QStringList const&) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #12 0x00007faaf67e79ee in QFileDialog::getOpenFileName(QWidget*, QString
> const&, QString const&, QString const&, QString*,
> QFlags<QFileDialog::Option>) () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #13 0x00007faa41f0c522 in QgsSpatiaLiteSourceSelect::newConnection(QWidget*)
>    from /home/sindile/apps/qgis3/lib/qgis/plugins/libspatialiteprovider.so
> #14 0x00007faa41f0c1f4 in QgsSpatiaLiteSourceSelect::on_btnNew_clicked()
> #15 0x00007faa41f19291 in QgsSpatiaLiteSourceSelect::qt_static_metacall(QObject*,
> QMetaObject::Call, int, void**) ()
> #16 0x00007faa41f19616 in QgsSpatiaLiteSourceSelect::qt_metacall(QMetaObject::Call,
> int, void**) ()
> #17 0x00007faaf593b644 in QMetaObject::activate(QObject*, int, int,
> void**) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #18 0x00007faaf66cfc12 in QAbstractButton::clicked(bool) () from
> #19 0x00007faaf66cfe64 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #20 0x00007faaf66d1257 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #21 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
> #22 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
> #23 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #24 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
> #25 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
> from /home/sindile/apps/qgis3/lib/libqgis_core.so.2.99.0
> #26 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
> QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #27 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
> QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) ()
> #28 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #29 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #30 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #31 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
> #32 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
> #33 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
> #34 0x00007faaf5e53723 in QGuiApplicationPrivate::processMouseEvent(
> QWindowSystemInterfacePrivate::MouseEvent*) ()
>    from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
> ---Type <return> to continue, or q <return> to quit---
> #35 0x00007faaf5e552a5 in QGuiApplicationPrivate::
> processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*)
> #36 0x00007faaf5e3323b in QWindowSystemInterface::
> sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
> #37 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5XcbQpa.so.5
> #38 0x00007faaebe89377 in g_main_context_dispatch () from
> /lib/x86_64-linux-gnu/libglib-2.0.so.0
> #39 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
> 2.0.so.0
> #40 0x00007faaebe8968c in g_main_context_iteration () from
> #41 0x00007faaf5963f0f in QEventDispatcherGlib::processEvents(QFlags<
> #42 0x00007faaf590d88a in QEventLoop::exec(QFlags<
> #43 0x00007faaf67d5a07 in QDialog::exec() () from
> #44 0x00007faaf8d4f967 in QgisApp::dataSourceManager(QString) () from
> /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
> #45 0x00007faaf8d5299c in QgisApp::createActions()::{lambda()#11}::operator()()
> const ()
>    from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
> #46 0x00007faaf8db9bbd in QtPrivate::FunctorCall<QtPrivate::IndexesList<>,
> QtPrivate::List<>, void, QgisApp::createActions()::{
> lambda()#11}>::call({lambda()#11}&, void**) () from
> #47 0x00007faaf8db8f89 in void QtPrivate::Functor<QgisApp::
> createActions()::{lambda()#11}, 0>::call<QtPrivate::List<>,
> void>({lambda()#11}&, void*, {lambda()#11}&*) () from
> #48 0x00007faaf8db760c in QtPrivate::QFunctorSlotObject<
> QgisApp::createActions()::{lambda()#11}, 0, QtPrivate::List<>,
> void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) ()
> #49 0x00007faaf593b81e in QMetaObject::activate(QObject*, int, int,
> #50 0x00007faaf65e0992 in QAction::triggered(bool) () from
> #51 0x00007faaf65e3380 in QAction::activate(QAction::ActionEvent) () from
> #52 0x00007faaf66d11fd in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #53 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
> #54 0x00007faaf679d66a in QToolButton::mouseReleaseEvent(QMouseEvent*) ()
> #55 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
> #56 0x00007faaf679d749 in QToolButton::event(QEvent*) () from
> #57 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #58 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
> #59 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
> #60 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
> #61 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
> #62 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #63 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5Widgets.so.5
> #64 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) ()
> #65 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
> #66 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
> #67 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
> #68 0x00007faaf5e53723 in QGuiApplicationPrivate::processMouseEvent(
> #69 0x00007faaf5e552a5 in QGuiApplicationPrivate::
> #70 0x00007faaf5e3323b in QWindowSystemInterface::
> #71 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/
> libQt5XcbQpa.so.5
> #72 0x00007faaebe89377 in g_main_context_dispatch () from
> #73 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
> 2.0.so.0
> #74 0x00007faaebe8968c in g_main_context_iteration () from
> #75 0x00007faaf5963f0f in QEventDispatcherGlib::processEvents(QFlags<
> #76 0x00007faaf590d88a in QEventLoop::exec(QFlags<
> #77 0x00007faaf5915ffc in QCoreApplication::exec() () from
> #78 0x0000559c46e06326 in main ()
> On Tue, Jun 20, 2017 at 1:31 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Zizi,
>> On Mon, 19. Jun 2017 at 20:11:53 +0200, Zizi Jama wrote:
>> > QGIS died on signal 11Could not attach to process.  If your uid matches
>> the
>> > uid of the target
>> Reading that instantly causes a strong urge to point at
>> http://qgis.org/en/site/getinvolved/development/bugreporting
>> .html#creating-a-backtrace
>> Jürgen
>> Jürgen E. Fischer           norBIT GmbH             Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>> +49-4931-918175-50
>> Software Engineer           D-26506 Norden
>> http://www.norbit.de
>> QGIS release manager (PSC)  Germany                    IRC: jef on
>> FreeNode
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170620/f299e1db/attachment.html>
