[Qgis-user] QGIS3 crashes when Open data source manager - Spatialite - New
Alessandro Pasotti
apasotti at gmail.com
Tue Jun 20 07:35:22 PDT 2017
I cannot reproduce those issues on master.
On Tue, Jun 20, 2017 at 4:15 PM, Zizi Jama <mazizi.jama at gmail.com> wrote:
> I also get a similar behaviour when
> Open data source manager - Delimited Text - Browse
> On Tue, Jun 20, 2017 at 3:03 PM, Zizi Jama <mazizi.jama at gmail.com> wrote:
>> Here is the backtrace
>> #0 __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/raise.c:58
>> #1 0x00007faaf4d6437a in __GI_abort () at abort.c:89
>> #2 0x0000559c46e00453 in qgisCrash(int) ()
>> #3 <signal handler called>
>> #4 0x00007faae2e79115 in XChangeProperty () from
>> /usr/lib/x86_64-linux-gnu/libX11.so.6
>> #5 0x00007faae2e96da9 in XSetTransientForHint () from
>> #6 0x00007faacf16d792 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
>> plugins/platformthemes/libqgtk3.so
>> #7 0x00007faacf170291 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
>> #8 0x00007faaf67d49c0 in QDialogPrivate::setNativeDialogVisible(bool)
>> () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
>> #9 0x00007faaf67e70d2 in QFileDialog::setVisible(bool) () from
>> #10 0x00007faaf67d58f1 in QDialog::exec() () from
>> #11 0x00007faaf67e7925 in QFileDialog::getOpenFileUrl(QWidget*, QString
>> const&, QUrl const&, QString const&, QString*, QFlags<QFileDialog::Option>,
>> QStringList const&) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
>> #12 0x00007faaf67e79ee in QFileDialog::getOpenFileName(QWidget*, QString
>> const&, QString const&, QString const&, QString*,
>> QFlags<QFileDialog::Option>) () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #13 0x00007faa41f0c522 in QgsSpatiaLiteSourceSelect::newConnection(QWidget*)
>> from /home/sindile/apps/qgis3/lib/qgis/plugins/libspatialiteprovi
>> der.so
>> #14 0x00007faa41f0c1f4 in QgsSpatiaLiteSourceSelect::on_btnNew_clicked()
>> der.so
>> #15 0x00007faa41f19291 in QgsSpatiaLiteSourceSelect::qt_static_metacall(QObject*,
>> QMetaObject::Call, int, void**) ()
>> der.so
>> #16 0x00007faa41f19616 in QgsSpatiaLiteSourceSelect::qt_metacall(QMetaObject::Call,
>> int, void**) ()
>> der.so
>> #17 0x00007faaf593b644 in QMetaObject::activate(QObject*, int, int,
>> void**) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
>> #18 0x00007faaf66cfc12 in QAbstractButton::clicked(bool) () from
>> #19 0x00007faaf66cfe64 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #20 0x00007faaf66d1257 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #21 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
>> #22 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
>> #23 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>> QEvent*) ()
>> #24 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
>> #25 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>> from /home/sindile/apps/qgis3/lib/libqgis_core.so.2.99.0
>> #26 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>> QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
>> #27 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
>> QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) ()
>> #28 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #29 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #30 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>> QEvent*) ()
>> #31 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
>> #32 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>> #33 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>> #34 0x00007faaf5e53723 in QGuiApplicationPrivate::proces
>> sMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) ()
>> from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
>> ---Type <return> to continue, or q <return> to quit---
>> #35 0x00007faaf5e552a5 in QGuiApplicationPrivate::proces
>> sWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) ()
>> #36 0x00007faaf5e3323b in QWindowSystemInterface::sendWi
>> ndowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
>> #37 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5XcbQpa.so.5
>> #38 0x00007faaebe89377 in g_main_context_dispatch () from
>> /lib/x86_64-linux-gnu/libglib-2.0.so.0
>> #39 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
>> 2.0.so.0
>> #40 0x00007faaebe8968c in g_main_context_iteration () from
>> #41 0x00007faaf5963f0f in QEventDispatcherGlib::processE
>> #42 0x00007faaf590d88a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
>> #43 0x00007faaf67d5a07 in QDialog::exec() () from
>> #44 0x00007faaf8d4f967 in QgisApp::dataSourceManager(QString) () from
>> /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>> #45 0x00007faaf8d5299c in QgisApp::createActions()::{lambda()#11}::operator()()
>> const ()
>> from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>> #46 0x00007faaf8db9bbd in QtPrivate::FunctorCall<QtPrivate::IndexesList<>,
>> QtPrivate::List<>, void, QgisApp::createActions()::{lam
>> bda()#11}>::call({lambda()#11}&, void**) () from
>> #47 0x00007faaf8db8f89 in void QtPrivate::Functor<QgisApp::createActions()::{lambda()#11},
>> 0>::call<QtPrivate::List<>, void>({lambda()#11}&, void*, {lambda()#11}&*)
>> () from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>> #48 0x00007faaf8db760c in QtPrivate::QFunctorSlotObject<
>> QgisApp::createActions()::{lambda()#11}, 0, QtPrivate::List<>,
>> void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) ()
>> #49 0x00007faaf593b81e in QMetaObject::activate(QObject*, int, int,
>> #50 0x00007faaf65e0992 in QAction::triggered(bool) () from
>> #51 0x00007faaf65e3380 in QAction::activate(QAction::ActionEvent) ()
>> #52 0x00007faaf66d11fd in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #53 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
>> #54 0x00007faaf679d66a in QToolButton::mouseReleaseEvent(QMouseEvent*)
>> #55 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
>> #56 0x00007faaf679d749 in QToolButton::event(QEvent*) () from
>> #57 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>> QEvent*) ()
>> #58 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) () from
>> #59 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>> #60 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>> #61 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
>> #62 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #63 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5Widgets.so.5
>> #64 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>> QEvent*) ()
>> #65 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) () from
>> #66 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>> #67 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>> #68 0x00007faaf5e53723 in QGuiApplicationPrivate::proces
>> #69 0x00007faaf5e552a5 in QGuiApplicationPrivate::proces
>> #70 0x00007faaf5e3323b in QWindowSystemInterface::sendWi
>> #71 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>> t5XcbQpa.so.5
>> #72 0x00007faaebe89377 in g_main_context_dispatch () from
>> #73 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
>> 2.0.so.0
>> #74 0x00007faaebe8968c in g_main_context_iteration () from
>> #75 0x00007faaf5963f0f in QEventDispatcherGlib::processE
>> #76 0x00007faaf590d88a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
>> #77 0x00007faaf5915ffc in QCoreApplication::exec() () from
>> #78 0x0000559c46e06326 in main ()
>> On Tue, Jun 20, 2017 at 1:31 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
>>> Hi Zizi,
>>> On Mon, 19. Jun 2017 at 20:11:53 +0200, Zizi Jama wrote:
>>> > QGIS died on signal 11Could not attach to process. If your uid
>>> matches the
>>> > uid of the target
>>> Reading that instantly causes a strong urge to point at
>>> http://qgis.org/en/site/getinvolved/development/bugreporting
>>> .html#creating-a-backtrace
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> http://www.norbit.de
>>> QGIS release manager (PSC) Germany IRC: jef on
>>> FreeNode
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170620/04fbf20c/attachment.html>
