[Qgis-user] QGIS3 crashes when Open data source manager - Spatialite - New
Zizi Jama
mazizi.jama at gmail.com
Mon Jun 26 10:20:46 PDT 2017
I guess this is not a qgis issue.
I followed this https://bugzilla.redhat.com/show_bug.cgi?id=1377616
Starting qgis with GDK_BACKEND=x11 qgis seems to address my issue.
Regards
On Tue, Jun 20, 2017 at 4:35 PM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> Hi,
> I cannot reproduce those issues on master.
> On Tue, Jun 20, 2017 at 4:15 PM, Zizi Jama <mazizi.jama at gmail.com> wrote:
>> I also get a similar behaviour when
>> Open data source manager - Delimited Text - Browse
>> On Tue, Jun 20, 2017 at 3:03 PM, Zizi Jama <mazizi.jama at gmail.com> wrote:
>>> Here is the backtrace
>>> #0 __GI_raise (sig=sig at entry=6) at ../sysdeps/unix/sysv/linux/rai
>>> se.c:58
>>> #1 0x00007faaf4d6437a in __GI_abort () at abort.c:89
>>> #2 0x0000559c46e00453 in qgisCrash(int) ()
>>> #3 <signal handler called>
>>> #4 0x00007faae2e79115 in XChangeProperty () from
>>> /usr/lib/x86_64-linux-gnu/libX11.so.6
>>> #5 0x00007faae2e96da9 in XSetTransientForHint () from
>>> #6 0x00007faacf16d792 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
>>> plugins/platformthemes/libqgtk3.so
>>> #7 0x00007faacf170291 in ?? () from /usr/lib/x86_64-linux-gnu/qt5/
>>> #8 0x00007faaf67d49c0 in QDialogPrivate::setNativeDialogVisible(bool)
>>> () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
>>> #9 0x00007faaf67e70d2 in QFileDialog::setVisible(bool) () from
>>> #10 0x00007faaf67d58f1 in QDialog::exec() () from
>>> #11 0x00007faaf67e7925 in QFileDialog::getOpenFileUrl(QWidget*, QString
>>> const&, QUrl const&, QString const&, QString*, QFlags<QFileDialog::Option>,
>>> QStringList const&) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
>>> #12 0x00007faaf67e79ee in QFileDialog::getOpenFileName(QWidget*,
>>> QString const&, QString const&, QString const&, QString*,
>>> QFlags<QFileDialog::Option>) () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #13 0x00007faa41f0c522 in QgsSpatiaLiteSourceSelect::newConnection(QWidget*)
>>> from /home/sindile/apps/qgis3/lib/qgis/plugins/libspatialiteprovi
>>> der.so
>>> #14 0x00007faa41f0c1f4 in QgsSpatiaLiteSourceSelect::on_btnNew_clicked()
>>> der.so
>>> #15 0x00007faa41f19291 in QgsSpatiaLiteSourceSelect::qt_static_metacall(QObject*,
>>> QMetaObject::Call, int, void**) ()
>>> der.so
>>> #16 0x00007faa41f19616 in QgsSpatiaLiteSourceSelect::qt_metacall(QMetaObject::Call,
>>> int, void**) ()
>>> der.so
>>> #17 0x00007faaf593b644 in QMetaObject::activate(QObject*, int, int,
>>> void**) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
>>> #18 0x00007faaf66cfc12 in QAbstractButton::clicked(bool) () from
>>> #19 0x00007faaf66cfe64 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #20 0x00007faaf66d1257 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #21 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
>>> #22 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
>>> #23 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>>> QEvent*) ()
>>> #24 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) ()
>>> #25 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>>> from /home/sindile/apps/qgis3/lib/libqgis_core.so.2.99.0
>>> #26 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>>> QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
>>> #27 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
>>> QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) ()
>>> #28 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #29 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #30 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>>> QEvent*) ()
>>> #31 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) ()
>>> #32 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>>> #33 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>>> #34 0x00007faaf5e53723 in QGuiApplicationPrivate::proces
>>> sMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) ()
>>> from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
>>> ---Type <return> to continue, or q <return> to quit---
>>> #35 0x00007faaf5e552a5 in QGuiApplicationPrivate::proces
>>> sWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) ()
>>> #36 0x00007faaf5e3323b in QWindowSystemInterface::sendWi
>>> ndowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
>>> #37 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5XcbQpa.so.5
>>> #38 0x00007faaebe89377 in g_main_context_dispatch () from
>>> /lib/x86_64-linux-gnu/libglib-2.0.so.0
>>> #39 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
>>> 2.0.so.0
>>> #40 0x00007faaebe8968c in g_main_context_iteration () from
>>> #41 0x00007faaf5963f0f in QEventDispatcherGlib::processE
>>> #42 0x00007faaf590d88a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
>>> #43 0x00007faaf67d5a07 in QDialog::exec() () from
>>> #44 0x00007faaf8d4f967 in QgisApp::dataSourceManager(QString) () from
>>> /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>>> #45 0x00007faaf8d5299c in QgisApp::createActions()::{lambda()#11}::operator()()
>>> const ()
>>> from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>>> #46 0x00007faaf8db9bbd in QtPrivate::FunctorCall<QtPrivate::IndexesList<>,
>>> QtPrivate::List<>, void, QgisApp::createActions()::{lam
>>> bda()#11}>::call({lambda()#11}&, void**) () from
>>> #47 0x00007faaf8db8f89 in void QtPrivate::Functor<QgisApp::createActions()::{lambda()#11},
>>> 0>::call<QtPrivate::List<>, void>({lambda()#11}&, void*, {lambda()#11}&*)
>>> () from /home/sindile/apps/qgis3/lib/libqgis_app.so.2.99.0
>>> #48 0x00007faaf8db760c in QtPrivate::QFunctorSlotObject<
>>> QgisApp::createActions()::{lambda()#11}, 0, QtPrivate::List<>,
>>> void>::impl(int, QtPrivate::QSlotObjectBase*, QObject*, void**, bool*) ()
>>> #49 0x00007faaf593b81e in QMetaObject::activate(QObject*, int, int,
>>> #50 0x00007faaf65e0992 in QAction::triggered(bool) () from
>>> #51 0x00007faaf65e3380 in QAction::activate(QAction::ActionEvent) ()
>>> #52 0x00007faaf66d11fd in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #53 0x00007faaf66d1434 in QAbstractButton::mouseReleaseEvent(QMouseEvent*)
>>> #54 0x00007faaf679d66a in QToolButton::mouseReleaseEvent(QMouseEvent*)
>>> #55 0x00007faaf662ea78 in QWidget::event(QEvent*) () from
>>> #56 0x00007faaf679d749 in QToolButton::event(QEvent*) () from
>>> #57 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>>> QEvent*) ()
>>> #58 0x00007faaf65ef9cd in QApplication::notify(QObject*, QEvent*) ()
>>> #59 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>>> #60 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>>> #61 0x00007faaf65ee07d in QApplicationPrivate::sendMouseEvent(QWidget*,
>>> #62 0x00007faaf66490f6 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #63 0x00007faaf664bb03 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5Widgets.so.5
>>> #64 0x00007faaf65e735c in QApplicationPrivate::notify_helper(QObject*,
>>> QEvent*) ()
>>> #65 0x00007faaf65eeb11 in QApplication::notify(QObject*, QEvent*) ()
>>> #66 0x00007faaf724be8d in QgsApplication::notify(QObject*, QEvent*) ()
>>> #67 0x00007faaf590f8a0 in QCoreApplication::notifyInternal2(QObject*,
>>> #68 0x00007faaf5e53723 in QGuiApplicationPrivate::proces
>>> #69 0x00007faaf5e552a5 in QGuiApplicationPrivate::proces
>>> #70 0x00007faaf5e3323b in QWindowSystemInterface::sendWi
>>> #71 0x00007faad2513830 in ?? () from /usr/lib/x86_64-linux-gnu/libQ
>>> t5XcbQpa.so.5
>>> #72 0x00007faaebe89377 in g_main_context_dispatch () from
>>> #73 0x00007faaebe895e0 in ?? () from /lib/x86_64-linux-gnu/libglib-
>>> 2.0.so.0
>>> #74 0x00007faaebe8968c in g_main_context_iteration () from
>>> #75 0x00007faaf5963f0f in QEventDispatcherGlib::processE
>>> #76 0x00007faaf590d88a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
>>> #77 0x00007faaf5915ffc in QCoreApplication::exec() () from
>>> #78 0x0000559c46e06326 in main ()
>>> On Tue, Jun 20, 2017 at 1:31 PM, Jürgen E. Fischer <jef at norbit.de>
>>> wrote:
>>>> Hi Zizi,
>>>> On Mon, 19. Jun 2017 at 20:11:53 +0200, Zizi Jama wrote:
>>>> > QGIS died on signal 11Could not attach to process. If your uid
>>>> matches the
>>>> > uid of the target
>>>> Reading that instantly causes a strong urge to point at
>>>> http://qgis.org/en/site/getinvolved/development/bugreporting
>>>> .html#creating-a-backtrace
>>>> Jürgen
>>>> Jürgen E. Fischer norBIT GmbH Tel.
>>>> +49-4931-918175-31
>>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>>> +49-4931-918175-50
>>>> Software Engineer D-26506 Norden
>>>> http://www.norbit.de
>>>> QGIS release manager (PSC) Germany IRC: jef on
>>>> FreeNode
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170626/e9a3b017/attachment.html>
