[Qgis-user] Principal Component Analysis ?
Benjamin Ducke benducke at fastmail.fm
Fri Jun 23 13:08:54 PDT 2017
Can you please stop patronizing people?
Please assume that GIS users can tell the
difference between _exploratory_ and _explanatory_
and are well aware of what specific statistical
methods can and cannot achieve. Whether
or not someone abuses statistical flexibility
is not a question that needs to concern
programmers, such as those that are behind
the _absolutely excellent_ R and the
_absolutely brilliant_ research and documentation
that goes with it, and is shared _absolutely freely_,
and in open source form, so that it can be reviewed
and improved (as opposed to closed source, paid-for
software) -- Thank you.
Best,
Benjamin
On 23/06/17 22:13, Falk Huettmann wrote:
> Hi,
> thanks but nope:
> CANOCO comes from the 1970s and is widely outdated by now,
> and not achieving (much).
> Just a few botanists (=not trained statisticians or coders) still use
> it, if at all.
> It usually asks the wrong questions and
> uses pretty old methods that are widely improved by now,
> e.g. machine learning. It all sits there instead, inference from
> predictions. Many publications on that matter.
> Sorry (any programmer knows it that machine learning performs 'very high').
> Like with LMs, GLMs and AIC, p-values or Bayesian stuff, CANOCO does not
> generalize nor predict so well.
> R is free, a hodgepodge of sorts, and thus, the cutting edge stuff does
> NOT all sit in R (high quality swords have a price, sorry).
> It's reality. Google etc are not programmed in R or with R for good reasons.
> Perhaps a certain blend is helpful, agreed, but hardly anything else.
> R packages also tend to suffer from poor conceptual reviews, e.g. what
> for and why ?
> Again,
> please be aware about such things.
> Just because it's statistics, coded by your good buddy, freeware, R (or
> QGIS), it's not all
> automatically good; often the opposite is the case.
> It's a fact and the crux you deal with here.
> A so-called hijacking by some coders and their mindsets; we saw it many
> times before,
> and it's self-serving.
> CANOCO is a great example for that.
> Kind regards
>    Falk
> Falk Huettmann PhD, Associate Professor
> Uni of Alaska Fairbanks UAF
> On Fri, Jun 23, 2017 at 11:56 AM, Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>> wrote:
>     Hi,
>     I am not at what needs to be analyzed in this case but yes,
>     canonical analysis needs to be well understood before being used.
>     You can go to Pierre Legendre and Louis Legendre, Numerical Ecology,
>     for help.  P Legendre also has a book on Spatial analysis in R that
>     can be found.
>     Cheers
>     Nicolas
>     P.S.
>     As far as statistical software, R is unbeatable for cutting edge
>     sciences. It is scary because it's a statistical language before
>     being a statistical software.  But I agree, some statistics are
>     implement in GIS software without any thought.
>     Le 23 juin 2017 à 15:11, Falk Huettmann <fhuettmann at alaska.edu
>     <mailto:fhuettmann at alaska.edu>> a écrit :
>>     Hi there,
>>     in my view and if I may comment here:
>>     while R is scary (as stated below),  so are probably many of the
>>     wrapped R packages really,
>>     PCAs are even more scary, and their underlying mindsets,
>>     and the real horror starts when such things get
>>     implemented into 'homebrews' and such tools, or
>>     into QGIS and just as point and klick.
>>     As a rule, I would highly suggest to stay clear of such efforts
>>     and concepts.
>>     It's no good science, and not much defendable. Unless well thought
>>     out,
>>     it harms the product and reputation you want to create.
>>     (for a bad example see Krigging in some major commercial GIS...
>>      We have seen such things many places).
>>     There should first be a good debate about statistics, if pursued
>>     as tools in QGIS etc.
>>     Arguably, unless it's predictive (for inference etc) it has no
>>     much value these days anymore.
>>     Agreed,
>>     it's a tragedy of our time that such old things still happen, all
>>     the time,
>>     and in the sciences.
>>     But it ain't no good, really, and is no good progress. My word for it.
>>     (I also agree that it is good to keep avenues open for such
>>     work, as an option and for people who know what they are doing and
>>     why; sure.
>>     But not more than that. Many bad examples exist all over for decades)
>>     Feel free to follow up as needed; kind regards
>>        Falk Huettmann
>>     On Fri, Jun 23, 2017 at 10:57 AM, Nicolas Cadieux
>>         Hi,
>>         You can use R for PCA.
>>         Use the R Commander package to add a GUI.  R can be scary at
>>         first.
>>         Nicolas
>>         Le 23 juin 2017 à 11:03, image [via OSGeo.org
>>         <http://OSGeo.org>] <[hidden email]
>>         <http:///user/SendEmail.jtp?type=node&node=5325361&i=0>> a écrit :
>>>         Good afternoon,
>>>         i'm working on windows with several opensource tools (qgis,
>>>         otb, grass...),
>>>         I generated several OTB texture indices. Now, i want to
>>>         evaluate the information 's redundancy thanks to a Principal
>>>         Component Analysis.
>>>         => Is it possible to do that with some opensource tools (otb?
>>>         qgis? grass?) Moreover, I would like set a mask AND set a
>>>         spectral subset (in order to ignore some indices bands which
>>>         seems "strange" and not relevant to introduce into the process).
>>>         Could you throw light for me?
>>>         In advance, thank you very much for your help.
>>>         Kind regards.
>>>         If you reply to this email, your message will be added to the
>>>         discussion below:
>>>         http://osgeo-org.1560.x6.nabble.com/Principal-Component-Analysis-tp5325338.html
>>>         <http://osgeo-org.1560.x6.nabble.com/Principal-Component-Analysis-tp5325338.html>
>>>         To start a new topic under QGIS - User, email [hidden email]
>>>         <http:///user/SendEmail.jtp?type=node&node=5325361&i=1>
>>>         To unsubscribe from QGIS - User, click here.
>>>         NAML
>>>         <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>         View this message in context: Re: Principal Component Analysis
>>         <http://osgeo-org.1560.x6.nabble.com/Principal-Component-Analysis-tp5325338p5325361.html>
>>         Sent from the QGIS - User mailing list archive
>>         <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html>
>>         at Nabble.com <http://Nabble.com>.
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>         Unsubscribe:
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
