[Qgis-user] Mini  dump when adding SQL layers QGIS 2.18.8
    Johanna Botman
    johannab at melton.vic.gov.au
    Sun Jun 25 15:54:24 PDT 2017
Thanks Martin, for getting back to me.
I have isolated that it this behaviour occurs when I load a layer from the browser window. If I add it through the Layer | Add New Layer menu items I don't have a problem. So that confirms what you are saying.
A shame, I like being able to drag and drop layers onto my projects. I'll have to investigate updating to the latest version.
Johanna Botman
Asset & GIS Officer | Melton City Council
[Melton logo colour - low res]   P: 03 9747 7209
   E: johannab at melton.vic.gov.au
   W: melton.vic.gov.au
From: Martin Bain [mailto:Martin.Bain at lismore.nsw.gov.au]
Sent: Monday, 26 June 2017 8:47 AM
To: Johanna Botman; qgis-user at lists.osgeo.org
Subject: RE: Mini dump when adding SQL layers QGIS 2.18.8
Hi Johanna,
2.18.8 was quickly replaced by 2.18.9 I think it had some issues - I don't know if any of them relate to your problem.
Are you adding the layers from the browser window or the add layer menu?
Are you using a named ODBC DSN or putting the SQL Server Host details directly into QGIS?  I had mini dumps when I was using named ODBC connections.
I'm afraid the only thing I can suggest, if you haven't already tried, is to try switching the way you are connecting and adding the layers.
Cheers,
Martin.
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/b6c692df/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/b6c692df/attachment.jpg>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170625/b6c692df/attachment-0001.jpg>
