[Qgis-user] Mini dump when adding SQL layers QGIS 2.18.8
    Nyall Dawson
    nyall.dawson at gmail.com
    Sun Jun 25 16:50:07 PDT 2017
On 26 June 2017 at 08:54, Johanna Botman <johannab at melton.vic.gov.au> wrote:
> Thanks Martin, for getting back to me.
> I have isolated that it this behaviour occurs when I load a layer from the browser window. If I add it through the Layer | Add New Layer menu items I don’t have a problem. So that confirms what you are saying.
> A shame, I like being able to drag and drop layers onto my projects. I’ll have to investigate updating to the latest version.
That's precisely the issue which 2.18.9 fixed :)
Update and you'll be right...
Nyall
> Johanna Botman
> Asset & GIS Officer | Melton City Council
>    P: 03 9747 7209
>    E: johannab at melton.vic.gov.au
>    W: melton.vic.gov.au
> From: Martin Bain [mailto:Martin.Bain at lismore.nsw.gov.au]
> Sent: Monday, 26 June 2017 8:47 AM
> To: Johanna Botman; qgis-user at lists.osgeo.org
> Subject: RE: Mini dump when adding SQL layers QGIS 2.18.8
> Hi Johanna,
> 2.18.8 was quickly replaced by 2.18.9 I think it had some issues – I don’t know if any of them relate to your problem.
> Are you adding the layers from the browser window or the add layer menu?
> Are you using a named ODBC DSN or putting the SQL Server Host details directly into QGIS?  I had mini dumps when I was using named ODBC connections.
> I’m afraid the only thing I can suggest, if you haven’t already tried, is to try switching the way you are connecting and adding the layers.
> Cheers,
> Martin.
> The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
> Qgis-user mailing list
