[Qgis-user] Unknown topology of empty WFS layer ?
Richard McDonnell
richard.mcdonnell at opw.ie
Fri Jun 30 03:39:19 PDT 2017
Not sure if this is exactly what you are looking for.
Your Layers, Ive no idea what database type you are using, but on
PostgreSQL/PostGIS you can put in geometry Constraints using
ALTER TABLE public."Table_Name"
and one of the following, depending on what Geometry type you are
looking at.
ADD CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) =
'MULTIPOLYGON'::text OR geom IS NULL);
'POLYGON'::text OR geom IS NULL);
'POINT'::text OR geom IS NULL);
'LINESTRING'::text OR geom IS NULL);
I hope this helps
Reagrds,
Richard
On 30/06/2017 10:39, Lars I. Nielsen, LIFA A/S wrote:
> Hi,
> I’m preparing a QGIS project for a customer, and have (among other)
> three layers with points, lines, and areas respectively.
> I’m adapting the project from a previously made project by altering
> the data connections. The databases are identical in structure, so it
> works. The layers are all fetched using WFS-T.
> So far I only have data in the points and areas layers, none in the
> lines layer. The lines dataset (table) in the database is present, and
> published as WFS (Geoserver), and all metadata (afaik) is present
> (i.e. “geometry_columns”).
> I would like to be able to digitize lines into the line layer, but
> apparently QGIS cannot determine the topology, and (I suppose that’s
> also why) I can’t add any styles via the “properties” dialog or elsewhere.
> Is there any way, that I can tell QGIS that the layer should contain
> line features ?
> And how can I add suitable (line) styles to display the lines without
> any features present ?
> Using 2.18.7 (32+64) Windows
> Med venlig hilsen
> *Lars I. Nielsen, LIFA A/S
> GIS-konsulent
> http://website.lifa.dk/lsp.gif
> *T*6313 6800 *@ *lin at lifa.dk
> *D *6313 6849 *W *www.lifa.dk
> *M *2492 4866
> Qgis-user mailing list
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170630/dbd1b2b2/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170630/dbd1b2b2/attachment.gif>
