[Qgis-user] Problem with georeferencer window
Sarah Gregg lynkosmail at gmail.com
Fri Mar 3 07:32:57 PST 2017
Thanks Richard, and of course I was talking about 2.18.4, more haste less
speed! I've found and tried the "Reset user interface to default settings".
It has reset everything... apart from bringing back the Georeferencer
window which remains stubbornly invisible :-(. Any other ideas? Sarah.
2017-03-03 16:19 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 03-03-17 16:10, Sarah Gregg wrote:
> > Hello everybody. I have a visualisation problem with the georeferencer
> > window that I just don't seem to be able to resolve. Some time ago, I
> > used the georeferencer on a second monitor. Now I no longer have that
> > second monitor, but when I try and open the georeferencer, it still
> > tries to open on the second monitor, so remains invisible. Is there some
> > way I can reset this? I'm using QGIS 2.1.8.4 on Windows 8.1. Thanks for
> > your advice, Sarah.
> Hi Sarah,
> QGIS (or actually Qt) 'remembers' the placing of the windows by writing
> them to the so called QSettings.
> We have seen people closing/removing panels and not being able to find
> them anymore.
> So (hoping that we are talking about QGIS 2.18.4 and not the ancient
> 2.1.8.4...) There is an setting in:
> Options/System named 'QSettings'
> It says 'Reset user inteface to default settings' and requires you to
> restart QGIS.
> Hope this helps else let us know.
> Regards,
> Richard
> ps for the (linux?) record: you could also start QGIS from commandline
> with the
> --defaultui option: "qgis --defaultui"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170303/12abc12f/attachment.html>
