[Qgis-user] Problem with georeferencer window
Richard Duivenvoorde rdmailings at duif.net
Fri Mar 3 08:01:33 PST 2017
On 03-03-17 16:32, Sarah Gregg wrote:
> Thanks Richard, and of course I was talking about 2.18.4, more haste
> less speed! I've found and tried the "Reset user interface to default
> settings". It has reset everything... apart from bringing back the
> Georeferencer window which remains stubbornly invisible :-(. Any other
> ideas? Sarah.
Mmm, another thing: I also know that the georeferencer window in Windows
sometimes is open, but behind the main window (somewhere), apparently it
does not always open in front. Can you check that?
And else I think GeoReferencer plugin saves it state itself, so other
then either attache a second monitor and move it back.
OR
Start QGIS with a fresh configuration like:
qgis.bat --configpath c:\foo
(sorry I'm not on Windows, but that is how you do it in Linux...)
Or else... have a nice weekend ;-)
Regards,
Richard
PS I tried to reset the values via:
Options/Avanced button I will be carefull...
and then reset the values of Plugin-GeoReferencer tree
but did not succeed...
