[Qgis-user] QGOS maps fort Garmin GPS
Brent Fraser bfraser at geoanalytic.com
Sun Mar 5 18:34:09 PST 2017
Stephen,
  Yeah I saw the other problems with surrounding creeks, but if I'm
going to replace the geometry with data from SCRD, I need to check that
their license agreement allows that.
OSM is NOT a satellite image map; it is strictly a vector database of
points, lines and polygons.  There are three ways to enter data into OSM:
     1. Upload your GPS tracks
     2. Digitize features using Bing imagery as a backdrop (this may be
where the confusion comes from)
     3. Do "bulk uploads" of license-compatible data (e.g. shapefiles of
Canvec 1:50k Fed data)
OSM is a collection of the best available, license-compatible data.
Bulk uploads are usually frowned upon, due to the ease of overwriting
existing data, so extra care must be taken.
I'll CC the OSM-Ca list (and we should drop out of the QGIS list unless
we have QGIS-related issues)
Best Regards,
Brent Fraser
On 3/5/2017 5:28 PM, Stephen Wandling wrote:
> Brent,
> OK.  You could have changed Robinson to Clough at the same time, if I
> had mentioned it.  But, the map is still missing Joe Smith Creek,
> which falls between Molyneux and Clough, and vast amounts of forks up
> the mountain for both of them.
> You may already know this, but you can get all the shape files at:
> http://www.scrd.ca/data-download
> If you can easily upload them to OSM, with their labels, then that
> would be useful to many people.  You can also get kmz files there.
> Importing them into Google Map shows the line, but not the label.
> Through all of this, I have come to realize something huge.  And that
> is simply that OSM is a sat view map.  For my GPS, I am only
> interested in topo maps.  I see enough of the trees when I am up
> there, so all I want on the GPS is streams and trails.  I will work
> with the contour lines that are on existing GPS map.  OSM, seemingly
> based on Bing maps, would not server my purposes.
> Thanks for your insights, work and views.
> Stephen
> On 05/03/2017 3:23 PM, Brent Fraser wrote:
>> Stephen,
>>   Based on the info from SCRD, I changed the name of Joe Smith Creek
>> to Molyneux Creek.
>> Best Regards,
>> Brent Fraser
>> On 3/5/2017 3:41 PM, Brent Fraser wrote:
>>> Hey Stephan,
>>>   This discussion may belong on the OSM-Canada mailing list
>>> (https://lists.openstreetmap.org/listinfo/talk-ca) so others can
>>> comment.
>>>   All maps contain errors, some intentional, others by mistake, and
>>> still others due to the passage of time.  The great thing about OSM
>>> is you can correct them!  The OSM community holds local knowledge in
>>> very high regard, and one of the basic guidelines is "If you think
>>> the data is wrong, change it."  I find the quality of the data very
>>> good, perhaps due to the majority of the editors have a passion for
>>> mapping.
>>>   I had a look at Joe Smith Creek in OSM.  It was imported from
>>> Canvec v10 (the Fed 1:50k data), and named the same on the BC 1:20k
>>> sheet. If you like, I could change the name...
>>> Best Regards,
>>> Brent Fraser
>>> On 3/5/2017 2:01 PM, Stephen Wandling wrote:
>>>> Phil,
>>>> For a government mapping agency to have a problem, it first has to
>>>> exist.  I am told that in 1992, British Columbia dismantled it's
>>>> cartography department and fired all of the cartographers. I am
>>>> also told that no work had been done on any of the 20K maps in the
>>>> prior 10 years.  So, only the private resource extraction
>>>> corporations have access to up-to-date digital data and at a price
>>>> that I certainly can not afford.
>>>> I had a look at OSM mountain biking maps last night, your second
>>>> link below.  I could see that someone had probably 'walked' what
>>>> they thought was Joe Smith Creek with their GPS, and extended what
>>>> had been on the base map.  First, that is Molyneux creek and not
>>>> Joe Smith, the base map was wrong and secondly that creek comes
>>>> from a large number of forks up the mountain, so they only dealt
>>>> with a small percentage of it's reach.  My immediate thought was
>>>> "This is Wikipedia for Cartography!". Errors laid upon errors. No
>>>> use of local knowledge or the Streams shape files available on the
>>>> Regional District's site.
>>>> That is a can of worms I am not interested in delving into.
>>>> Cheers,
>>>> Stephen
>>>> On 04/03/2017 8:28 PM, Phil (The Geek) Wyatt wrote:
>>>>> No problems Stephen,
>>>>> Unfortunately many government agencies can't keep up with edits of
>>>>> new tracks/trails but that is the beauty of Open Street Map. Your
>>>>> contribution, by adding tracks, means that all the folks making
>>>>> derivative products get the benefits. You also get the benefit of
>>>>> their knowledge in the creation of products to suit your GPS.
>>>>> Indeed you can even use OSM mapping as a background in QGIS so you
>>>>> get the same benefits immediately.
>>>>> If you have some GPS files, drop me a few and I will get them
>>>>> loaded for you to get you started.
>>>>> The Mountain bike community are quite active in some areas and
>>>>> have great wiki information on tagging for trails
>>>>> http://wiki.openstreetmap.org/wiki/Mountain_biking
>>>>> https://openmtbmap.org/
>>>>> Cheers - Phil
>>>>> -----Original Message-----
>>>>> From: Stephen Wandling [mailto:swandling at gmail.com]
>>>>> Sent: Sunday, March 5, 2017 12:14 PM
>>>>> To: Phil (The Geek) Wyatt
>>>>> Cc: qgis-user at lists.osgeo.org
>>>>> Subject: Re: [Qgis-user] QGOS maps fort Garmin GPS
>>>>> Phil,
>>>>> Someone suggested the same OSM approach in an off list email. Here
>>>>> was my response:
>>>>>> I have just taken a look at OSM, and the maps there, for my area of
>>>>>> interest, are taken from the ancient (pre 1992) British
>>>>>> Columbia/Canada maps that are very incomplete and riddled with
>>>>>> errors.
>>>>>> It is because there are no accurate maps of this area that I resumed
>>>>>> my struggles with GIS and have been making maps and having them
>>>>>> plotted.
>>>>> The areas I am creating maps for are entirely forest areas, with
>>>>> streams, trails, roads, parks and that is about it.  No buildings,
>>>>> streets, etc.
>>>>> In the last 20 years or so the mountain bikers and hikers, have
>>>>> put in and documented hundreds of kilometers of trails along this
>>>>> coast.  The OSM maps have a single digit percentage of what is
>>>>> here now.  And many they do have have been obliterated by clear
>>>>> cut logging operations.
>>>>> I have been making simple maps, that meet my needs, and having
>>>>> them plotted at a local facility for $15 each, which is cheaper
>>>>> than the incomplete/error ridden maps that one can purchase.  I
>>>>> use these maps to travel through this area on foot.
>>>>> Now I wanted a better map for my GPS.  So far, no luck.
>>>>> Stephen
>>>>> On 04/03/2017 4:28 PM, Phil (The Geek) Wyatt wrote:
>>>>>> Depending on the size of the area involved and how 'custom' your
>>>>>> maps
>>>>>> are likely to be you may be better off looking at solutions from
>>>>>> OSM.
>>>>>> There are many sites that create files suitable for Garmin GPS
>>>>>> http://garmin.openstreetmap.nl/
>>>>>> If the areas are small you could also create KMZ (Google Earth
>>>>>> Files) and transfer them to your garmin device. These can be
>>>>>> created in QGIS. Look at the plugin GarminCustomMap.
>>>>>> Cheers - Phil
>>>>>> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf
>>>>>> Of Stephen Wandling
>>>>>> Sent: Sunday, March 5, 2017 11:03 AM
>>>>>> To: qgis-user at lists.osgeo.org
>>>>>> Subject: [Qgis-user] QGOS maps fort Garmin GPS
>>>>>> I am running QGIS 2.18.3 and am at a very early learning stage.
>>>>>> I wish to create simple maps, with 2 or 3 shape files for my
>>>>>> Garmin GPSMaps 76CSx.  This map would consist of Trails and
>>>>>> Streams shp files and maybe Contours.  It would also be accepted
>>>>>> by Mapsource and Base Camp.
>>>>>> There were some tutorials that seemed like they were what I
>>>>>> wanted, but they all failed in one regard or another: 1.) They
>>>>>> were using an 'ancient' version of qgis.  2.) The maps they
>>>>>> produced worked in just about every Garmin GPS except the one I
>>>>>> own.  3.) They use a plug-in with a disclaimer that it will
>>>>>> demolish my data.  There were other issues, but my memory fails me.
>>>>>> If someone out there is familiar with my situation (and possibly
>>>>>> has the same GPS) and can either point me to a site I missed, or
>>>>>> outline the steps for me, I would be grateful.
>>>>>> [If it is easier to do in ArcMap, I have access to the ESRI software
>>>>>> also.]
>>>>>> Please keep in mind that while I have a general idea about GIS
>>>>>> work and have been making some maps, for plotting, that satisfy
>>>>>> my needs, I get very lost when I am subjected to acronyms and
>>>>>> technical jargon.  If is not clear and straightforward, it will
>>>>>> probably be wasted on me.
>>>>>> TIA,
>>>>>> Stephen
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
