[Qgis-user] Coordinates in map units are different between ArcInfo and Qgis
Tudorache, Marian Marian.Tudorache at navcanada.ca
Tue Mar 7 10:19:18 PST 2017
Hi Mark,
The projection that I use in Qgis and ArcInfo is:
QGIS: +proj-sterea +lat_0=53.5 + lon_0=-76.0 +k=0.9996 +x_0=0.0 +y_0=0.0 +a=631816.16075 +b=631816.16075 +units=m +nodefs
ArcInfo: has different representation but the same thing:
Projection           STEREOGRAPHIC
Datum                  NONE
Zunits                   NO
Units                     METERS
XShift                    0.00000000000
YShift                    0.00000000000
Parameters         631816.16075 0.00000000000
                              1 /* Projection type < 1 | 2 >
631816.16075       /*radius of sphere of reference
-76   0 0.000           /* longitude of center of projection
53    30 0.000         /* latitude of center of projection
0.00000                  /* false easting (meters)
0.00000                  /* false westing (meters)
One more thing ArcInfo uses directive COORDINATES in AML to extract the coordinates.
Thanks,
Marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Mark Seibel
Sent: March-07-17 11:18 AM
To: Tudorache, Marian
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Coordinates in map units are different between ArcInfo and Qgis
Hi.
Can somebody explain me why coordinates in map units read by Qgis are different than those read by ArcInfo?
How can I make the two coordinates to be the same?
What is the projection of the arc/info coverage?
Is QGIS set to the same projection?
Mark
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170307/e80d21b7/attachment.html>
