[Qgis-user] Coordinates in map units are different between ArcInfo and Qgis
Mark Seibel mseibel at gmail.com
Tue Mar 7 12:17:34 PST 2017
If you fire up ArcEdit what are the coordinates at some comparable location
in QGIS? (as opposed to the coordinates usage in AML)
Or if you view the A/I coverage in another software like ArcView
3.x/ArcMap, are the coordinates the same in QGIS?
Maybe try converting your coverage to a shapefile, and see if there is a
difference?
Another option is to set no coordinate system, or disable 'project on the
fly', and see what the coordinates are for the data.
Just some suggestions, I really cant explain why there difference. AFAIK,
A/I coverages shouldnt matter, but they are rather archaic.
Mark
On Tue, Mar 7, 2017 at 1:19 PM, Tudorache, Marian <
Marian.Tudorache at navcanada.ca> wrote:
> Hi Mark,
> The projection that I use in Qgis and ArcInfo is:
> QGIS: +proj-sterea +lat_0=53.5 + lon_0=-76.0 +k=0.9996 +x_0=0.0 +y_0=0.0
> +a=631816.16075 +b=631816.16075 +units=m +nodefs
> ArcInfo: has different representation but the same thing:
> Projection           STEREOGRAPHIC
> Datum                  NONE
> Zunits                   NO
> Units                     METERS
> XShift                    0.00000000000
> YShift                    0.00000000000
> Parameters         631816.16075 0.00000000000
>                               1 /* Projection type < 1 | 2 >
> 631816.16075       /*radius of sphere of reference
> -76   0 0.000           /* longitude of center of projection
> 53    30 0.000         /* latitude of center of projection
> 0.00000                  /* false easting (meters)
> 0.00000                  /* false westing (meters)
> One more thing ArcInfo uses directive COORDINATES in AML to extract the
> coordinates.
> Thanks,
> Marian
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Mark Seibel
> *Sent:* March-07-17 11:18 AM
> *To:* Tudorache, Marian
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Coordinates in map units are different between
> ArcInfo and Qgis
> Hi.
> Can somebody explain me why coordinates in map units read by Qgis are
> different than those read by ArcInfo?
> How can I make the two coordinates to be the same?
> What is the projection of the arc/info coverage?
> Is QGIS set to the same projection?
> Mark
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170307/48c9e296/attachment.html>
